Off topic = Gas BBQ burner
Speaking of that, in low and dirty gas areas such as a lot of areas around Boston. it gets prey ugly when installers install appliances with a minimum pressure rating than what is delivered at the property, as well gas company only guarantees a pressure just under 5 in. W/C...Wind certinaly has an effect on performance of outdoor grills...Why cook outdoors with natural gas? Most people like it for the flavoring, I still use charcoal...Wish I could afford the Green Egg..But I can't .....ChrisJ said:Suzook said:Oh, That's a strange arangement. Mine is different. Probably too much pressure. Pushing more gas at the end???
That's the thing though.JUGHNE said:That would be my guess....lower the pressure with reg.
They rated it for 7" WC, and I'm at 6.5" WC. If I lower the pressure I'll have less heat overall and I don't want that either.0 -
Why not?
BTW, my wife hates the smokey taste of charcoal. I can get away with using lump charcoal, but never Kingsford with her. She says it tastes like burning tires.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Chimney only, no lighter fluid.ratio said:ChrisJ said:it tastes like burning tires.
Maybe you're using too much Boy Scout juice?
It's a common flavor during the summer months around here unfortunately.
I usually put a wad of new paper, or even paper towels in the bottom and light'r up.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
If anyone has ever used a chimney starter they will forget about the existence of lighter fluid. The chimney starter is truly wonderful.ratio said:ChrisJ said:it tastes like burning tires.
2 -
Exactly. You know it's done when you can nearly see a tongue of flame coming out the top.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
https://youtu.be/Q90WH2_e-U8
