Unusual Installation...
The supply going off to the right forms a big loop around the basement and returns to the boiler at the duct-tape-wrapped tee. You can imagine what happens when the steam goes left and opposes the returning condensate...
New England SteamWorks
newenglandsteamworks.com
    Steamhead Member Posts: 18,205
    The solution is obvious- but we all know what's under the duct tape, don't we?
    Consulting
    kcopp
  • Ironman
    Ironman Member Posts: 7,858
    But... He was probably the low bidder. Or, the only one that knows steam. :*
    Bob Boan
  • jumper
    jumper Member Posts: 2,501
    Does it work?
  • Paul48
    Paul48 Member Posts: 4,469
    edited January 2017
    Ooops.....Ya mean it wasn't the neighbors making that noise, at all hours of the day and night? :wink: Two-pipe steam with monoflow tees......the Cadillac of heating systems!
    Danny ScullyRomanGK_26986764589
  • rick in Alaska
    rick in Alaska Member Posts: 1,514
    I don't do steam because there is none around here, but isn't the pigtail supposed to be vertical?
    Rick
  • j a_2
    j a_2 Member Posts: 1,804
    Nope....that's and old mercury thing....but, that said, in plumbing everything should be installed in a workmanship like manner.
  • Abracadabra
    Rick
    The outlet of the pigtail should be pointing up. They should have used a 90 pigtail there instead of the straight.
