Unusual Installation...
New England SteamWorks
Member Posts: 1,506
The supply going off to the right forms a big loop around the basement and returns to the boiler at the duct-tape-wrapped tee. You can imagine what happens when the steam goes left and opposes the returning condensate...
newenglandsteamworks.com
The solution is obvious- but we all know what's under the duct tape, don't we?All Steamed Up, Inc.
Consulting1 -
But... He was probably the low bidder. Or, the only one that knows steam.Bob Boan
Does it work?0
I don't do steam because there is none around here, but isn't the pigtail supposed to be vertical?
Rick0 -
Nope....that's and old mercury thing....but, that said, in plumbing everything should be installed in a workmanship like manner.0
The outlet of the pigtail should be pointing up. They should have used a 90 pigtail there instead of the straight.rick in Alaska said:I don't do steam because there is none around here, but isn't the pigtail supposed to be vertical?
Rick0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
