Counterflow
Danny Scully
Member Posts: 1,462
Just a thought. I'm working out a counterflow repipe. Just thinking about pipe sizing. Would you think reducing the size as the load drops off the main would matter? For example, the load requires 3", after I pass the point of needing 3", I'm think of dropping to 2-1/2, 2, and so on (with eccentric fittings of course). I can't see the downside, but that's why I'm asking.
I can't see a downside either, @Danny ScullyBr. Jamie, osb
I think as long as the reduced pipe can handle the EDR from that point on along with the counterflow condensate you should be fine.0
I'm not sure. Idea is that less pressure drop by continuing same size compensates for farther?0
Not exactly sure what you're saying @jumper but the math I've done leads me to believe it will work. I'll definitely keep the wall posted0
Understood @Hatterasguy. The 2" portion is only carrying about 100 sqft for example.0
utilize the ashve charts, would be my recommendation..my favorite are the 1937 charts, but every year had a book.gwgillplumbingandheating.com
Don't make me beg @gerry gill, where would I find them?0
Another quick thought. I'm going to pipe this boiler with a drop header, takeoffs, and equalizer (as usual) as opposed to the typical drawing you'll find for counterflow. The takeoffs will drop into the top of the counterflow mains as well. Again, no downside right?0
Well, the job is in full swing. I had the great pleasure of working with @EzzyT today. We were able to get a good portion of one of the counterflow mains complete. In doing that, we had to pipe around multiple obstructions, but with a little creativity (and patience), we made it work. The main decreases from 3, to 2-1/2, to 2, to 1-1/2 as the load gets lighter along the way. More progress to come.0
Is that piping in the second picture going around the old coal chute?
3PSI gauge0 -
No it's the chimney clean out which the customer still plans to use.0
This is the original Arco boiler0
Wow, that's when they made REAL boilers! I love it.0
nice job guys! @EzzyT & @Danny Scully .... I love the piping setup to go around the obstruction .... I used it once to go around a metal beam....ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0 -
Thanks @Mad Dog!0
drop header instead of typical counter flow arrangement is fine, but the risers to the system piping should not go straight up from the header, they should go up on a 45 degree angle. you want the returning condensate staying on the bottom side of the pipe, not dropping like water fall against the high speed flow of steam.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Worked for a little while tonight and finished the counterflow main me and @ezzyt started. Starting the 2nd counterflow main Saturday. More progress to come.0
2nd counterflow main complete from basement to third floor.3
@Danny Scully that's SOME repipe, looks awesome.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Thanks @Dave0176! Essentially, it's a complete repipe.0
Yes, it is. Which begs the question: Why are we starting the thread in the middle?! How did this all come about? It looks like a fascinating project and inquiring minds want to know why in 2016 there isn't pex and circulators? How did you pull that off?Danny Scully said:Thanks @Dave0176! Essentially, it's a complete repipe.
I am completely jealous...
I assume you know, but don't forget the vents at the ends of the counterflow mains. And keep the pics coming!
New England SteamWorks
newenglandsteamworks.com0 -
Well I was requested by the customer, who had just bought the house, to inspect their steam heating system and present them with an estimate to convert to forced hot water...I accepted the request but explained I would be more inclined to present them with an estimate to maintain their existing steam system for any number of reasons which I would go over with them upon my site visit. Ultimately, I made their decision easy when I explain their beautiful ornate radiators were not connected at the top, and only functioned as steam radiators. Then, an exchange of estimates (from parallel flow, to counterflow) finally concluded with the counterflow option, as it reduced labor time. Engineering the project was fun, with the mains reducing in size as the load got lighter. The 2nd main actually goes from 2-1/2, to 2, to 1-1/2, back to 2 for a horizontal portion that couldn't be handled by 1-1/2, then back to 1-1/2. The main vent(s) in the first series of pictures will be located at the 1st open tee, in the first picture I think. The 2nd main will be vented at the top of the riser on the 3rd floor. I'll keep the pictures coming!0
What type of eccentric fittings did you use to go 1.5-2-1.5, counter-flow?0
It's 1-1/2 on the vertical, then 2" on the horizontal to a 2 X 1-1/2 X 1-1/2 tee. No eccentric fittings needed.0
Looks great...except for that rusty ell atop the equalizer.Bob Boan
Hopefully you have enough pitch isn't counter flow 1"/10'??0
Yes @EBEBRATT-Ed, it is, and yes, we do. It's all 1/8" per foot minimum.0
@Danny Scully Excellent!! Nice looking job. Never thought of this before but is there a maximum distance you can go with counter flow without dripping???
I guess if the pipe is sized right and you don't run out of pitch you can go as far as you want??0 -
I think the practical limit is 100 feet @EBEBRATT-Ed0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
