Barnes & Jones Big Mouth Vent
BrianT1077
Member Posts: 108
Today I received my Barnes & Jones Big Mouth Vent via Amazon. It feels solid and very well built, unlike the Gorton # 1 which feels tinny. Wish I could test it on my system but it is 80 degrees outside, and I am actually running the A/C so that is not happening. I have 4 Gorton # 1's on an antler for my largest main which the B&J is going on and they all spit steam and water and they were replaced under warranty for doing the same thing. This weekend the temp is going to drop into the 40's so I will install it then and run the test. Anyone out there who has this vent, what are your opinions? From what I read and researched on here, they are all favorable. I heard about this vent on here and also this vent came recommended from @Dave0176 who evaluated my steam system in the past few weeks.
Crown Boiler Bermuda Series model: BSI103, BTU output: 85,000, single pipe steam system
1
I have about a total of 8 out there so far and love them.....they also have an adjustable varivent its a little smaller i sometimes install on risers....heres a few pics
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company3 -
I bought five of them for my system, two on a long main, one each on two other mains and one on a branch off of one of the mains. I did have multiple Hoffman 75's on my system and I can't wait to see how these perform too. It's been in the 80's here too. They are extremely well built and they are rebuild-able if they ever need to be.0
I've put in dozens. No question in my mind they are the finest main vents available. No reason for Gortons any longer.New England SteamWorks
newenglandsteamworks.com7 -
Thank you for the great responses everyone, I really appreciate the strong faith in the product that we the end users or your customers give. When I took it out of the box yesterday I felt it was a well made quality product.Crown Boiler Bermuda Series model: BSI103, BTU output: 85,000, single pipe steam system0
no one else can touch the quality, that is for sure. We just got in another dozen of the big mouths and a dozen vari vents.gwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.2 -
Thank you again for all the nice comments and testimonials. And let's not forget this was a collaboration of many on the Strictly Steam board to come up with a better product. None of it would be possible without the suggestions, brainstorming and testing of many of you.
I welcome your feedback on Amazon, your comments and ratings help answer many of the questions in a central location.
PeterPeter Owens
SteamIQ4 -
Today I swapped out the 4 Gorton # 1's for the Big Mouth Vent. Tested everything, so far so good!
Before:
After:
Crown Boiler Bermuda Series model: BSI103, BTU output: 85,000, single pipe steam system5 -
@mookie3333 I've been running my boiler for a week now with my Bigmouths. The first night I just wandered around the basement and marveled at them.
They work beautifully. I replaced a bunch of Hoffman 75's. I'm sure you can find someone here that hasn't seen the light yet and will take those Gortons off your hands. 2 -
The bigmouth has 4X the venting capacity of the 75 so if you need more venting, go for it. I have had two Hoffman 75's start leaking steam within 18 months of being installed, as far as I'm concerned they are junk.
3PSI gauge1 -
Thanks for the info Bob. I can hear one of the 75's when it is venting the air, so i'm guessing that's an indication more venting is needed on that line.BobC said:The bigmouth has 4X the venting capacity of the 75 so if you need more venting, go for it. I have had two Hoffman 75's start leaking steam within 18 months of being installed, as far as I'm concerned they are junk.
With a two pipe system like mine, where the condensate lines are vented though the condensate pump (as shown in the diagram below), what are the advantages/improvements I can expect with faster venting mains?
I pulled the trigger today and got 5 of these from Supply House
with a last minute switch from Gorton #2s, but then I got to thinking - Will vacuum pull them open and allow air into the system? My 2 pipe trane system pulls a vacuum and I think it makes sense to keep it that way.0 -
Anecdotally I can say that mine breaks after my Gorton #1 does, but I'm not sure if it's breaking due to vacuum or due to temperature. I think my radiator vents and/or my Gorton #1 (on the same main) relieve the vacuum before the Big Mouth opens.
Just converted a single piped systems dry return into a went return and added a big mouth. So far so good. Works great1
> @Sailah said:
> Vacuum won't pull them open just temp about 15 degrees below saturated.
Yes. On larger vapor systems, you can get a lot of whistling if you’ve sized down all the vents on the radiators... as you should.
You can add a vacuum break to the end of the antler.0
- 87.1K THE MAIN WALL
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
