Reversing a conversion
Question I have is has anyone ever converted people back to oil?
I know I never have.
cell # 413-841-6726
I'm curious why anyone would ever consider such a thing?
They think once they switch to gas the price of gas will skyrocket and oil will drop.Cost is what you spend , value is what you get.
cell # 413-841-6726
We haven't. Oil has such a bad reputation in this area that everyone wants to switch to gas. I think it's only a matter of time before the permitting authorities no longer approve the installation of oil-fired heating equipment. All it will take is one badly leaking tank.All Steamed Up, Inc.
Consulting0 -
In order to be approved within inspection in my area the oil tank does need to be removed unless a dual-fuel boiler is installed. But at this point they are only very large residential or commercial buildingsCost is what you spend , value is what you get.
cell # 413-841-6726
Betting on anything in the energy industry is crazy, but I'll make an exception for this: Liquid fuels carry a significant premium on a per-BTU basis due to their near-monopoly of the transportation industry. That situation is unlikely to change any time soon.Charlie from wmass said:They think once they switch to gas the price of gas will skyrocket and oil will drop.
Imagine if they had piped oil to houses through meters instead of using tanks.Cost is what you spend , value is what you get.
cell # 413-841-6726
Buyer's remorse? So many of our comments here sort of implicitly assume that natural gas is already in the building, or at least right near by and thus available. But there are still a few folks -- such as myself -- who are beyond the possibility of natural gas any time in the near future, and there are companies out there who will cheerfully tell us that we will save piles and piles of money if we convert to LP (don't worry, @Charlie from wmass -- I'm not about to!). Then you do the conversion and you find that... um... no... not so much. If any. And LP does have some downsides (so does oil, before someone jumps on me) to consider, which aren't always mentioned by the sales people (or properly taken into account by the installers -- such as tanks way too small in very cold weather).ChrisJ said:I'm curious why anyone would ever consider such a thing?
Come on @Jamie Hall LP has no downsides vs oil.
Especially when you consider not everyone has a Charles, or a Steamhead or 20 other guys on this forum that will actually service their burner.
Most are stuck with guys that don't even take the sootvac off the truck or change the filters. This isn't oil it self's fault, but it is reality.
When it comes down to it, for most people LPG will be superior overall even with an additional cost for fuel.
I'm not saying people should convert from oil to LPG for no reason, but if the boiler is being replace etc, I would consider it. Natural gas obviously is a no brainer.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
And MegaSteam!New England SteamWorks
newenglandsteamworks.com0 -
Megasteam afue is less than 1% higher than a Weil Mclain SGO and I can run gas in a SGO. Why burn oil? I also provide service for gas customers as any of us can so still not enough to go back to oil as far as I can see. Note not arguing with you, just not sure how that switch could be justified from a fiscal view point.Cost is what you spend , value is what you get.
cell # 413-841-6726
I don't think it can. But that applies either way... of course I have a competent chap to service Cedric, so perhaps I am biased!Charlie from wmass said:Megasteam afue is less than 1% higher than a Weil Mclain SGO and I can run gas in a SGO. Why burn oil? I also provide service for gas customers as any of us can so still not enough to go back to oil as far as I can see. Note not arguing with you, just not sure how that switch could be justified from a fiscal view point.
And if gas is ever availible Cedric can be converted.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating2 -
If all oil guys behaved like you, oil would have a far far better name.RI_SteamWorks said:
And MegaSteam!
Sadly, most are not like you.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
Luckily we have just acquired gas here, so have more options. Before it was just oil, propane, or electric. Electric is around 22cents, oil down to about $2.30 or so, and propane is now down to about $3.90. At one time, propane was over $5.00 and I had figured it out to be 8 times the cost of oil. And I had used an 86% oil unit and compared it to a 95% lp unit. Propane is the absolute last option around here, especially now with natural gas..
That being said, there are people who are not next to a gas line, and because of health concerns can not be around oil. Then they are stuck with lp, or electric.
On the other side of the coin are my neighbors who would never have any kind of gas because they know they will blow up!
Something for everyone.
Rick
It's funny how different things are in different areas. 10 years ago 99% of heat commercial and residential was oil. Even roof top units...now there is something you don't want to service when it's -20F and the gelled oil oil won't pull from the underground tank. Friday evening setback and a couple of hours without a call for heat and bam no oil to the burner. Not fun at all.
Propane has the distinction that you need many tanks to get enough vaporization on those below zero days. Oil can be drawn from a tank at as fast as rate as needed. We have installed quite a few power flame dual fuel burners for customers who have underground tanks that are still in good shape. Also have direct vaporizers, indirect, and electric vaporizers out there.
TaylorServing Northern Maine HVAC & Controls. I burn wood, it smells good!0 -
Yikes!Charlie from wmass said:Imagine if they had piped oil to houses through meters instead of using tanks.
If you need a "sootvac" the burner wasn't set up properlyChrisJ said:Come on @Jamie Hall LP has no downsides vs oil.
I'm not saying people should convert from oil to LPG for no reason, but if the boiler is being replace etc, I would consider it. Natural gas obviously is a no brainer.To learn more about this professional, click here to visit their ad in Find A Contractor.2 -
@Robert O'Brien am I allowed a cup or cup and a half in a Weil Mclain 580? If not I will pm you to learn to do it better. Note sincere, not sarcastic.Cost is what you spend , value is what you get.
cell # 413-841-6726
https://heatinghelp.com/find-a-contractor/detail/charles-garrity-plumbing-and-heating1 -
CNG is available for properties with enough room for a trailer.State & local authorities have to suck it up on account of federal DOT approval.0
That's a properly running burner that's been maintained.Robert O'Brien said:
If it's like most out there, you'll need a sootvac and a 50 gallon garbage can to empty the vacuum into multiple times.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Way back when I was with the gas company and was putting in hundreds of gas conversions we always left the old oil burner on the job. Back then the oil tank did not have to be removed. Rarely we would go back and reinstall the old oil burner. I can count maybe 5 or six that I did. What usually happened was a new gas boiler was installed once the boiler was no longer repairable.
In those days we rented the conversion burner to the customer for $5.00 a month and gave them a rental storage water heater for $2.50 a month. We maintained them, repaired them at no charge and replaced parts and if the tanks went or the burners we replaced them. The whole idea was to SELL GAS!1 -
They did a similar thing in the early 20th century with electricity. Light bulbs were given to consumers so they would use more of it. In some areas you could buy a unit of electricity by putting a coin in the meter.
3PSI gauge0 -
Fans were rented as well early on.BobC said:They did a similar thing in the early 20th century with electricity. Light bulbs were given to consumers so they would use more of it. In some areas you could buy a unit of electricity by putting a coin in the meter.
Bob
Coin electric meters were in use recently in Ireland. If they are not still used.Cost is what you spend , value is what you get.
cell # 413-841-6726
Many years ago gas meters used for strictly gas lights had a coin operation that needed quarters to be installed to get gas. Folks got very creative and would freeze ice the same size as a quarter which would make the meter work. We would find this out when the meter finally filled up with water and would not work.1
Ah, the good old days.0
Wonder how much money was spent freezing the water?Tim McElwain said:Many years ago gas meters used for strictly gas lights had a coin operation that needed quarters to be installed to get gas. Folks got very creative and would freeze ice the same size as a quarter which would make the meter work. We would find this out when the meter finally filled up with water and would not work.
If it was winter time not muchCost is what you spend , value is what you get.
cell # 413-841-6726
I was surprised and gas company was disappointed by how long it took residences to convert. Why not take away old burners to sell to junk dealer?0
Because the burner is the owners property not ours.Cost is what you spend , value is what you get.
cell # 413-841-6726
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
