Whoops!
Harvey Ramer
Harvey Ramer Member Posts: 2,281
Think I can get a warranty on this? I swear I had my hands in my pockets and was just standing there when it happened.
Or maybe I could go with, the pump sucked it flat? lol
Rich_49Steve MinnichErin Holohan Haskell
  • kcopp
    kcopp Member Posts: 4,628
    wrong size jaws?
    hot_rod Member Posts: 26,579
    A venturi style iso-flange, nice invention!
    pecmsg Member Posts: 6,769
    Sta Brite #8 can fix that!
    njtommy
  • Paul48
    Paul48 Member Posts: 4,469
    Does it whistle when you blow on it? It's a stocking stuffer!!!
  • njtommy
    njtommy Member Posts: 1,105
    Sometimes you just forget to think.
    Steamhead Member Posts: 18,196
    No problem, that'll buff out.
    Consulting
  • Abracadabra
    lol! nothing a bit of solder won't fix ;)
  • Gordy
    Gordy Member Posts: 9,546
    That moment when you laugh at yourself?
    njtommyZman
  • Canucker
    Canucker Member Posts: 723
    Get the hammer out. If that doesn't fix it, it's obviously an electrical problem :smile:
    You can have it good, fast or cheap. Pick two
    Tom_133Erin Holohan HaskellLeo_G
  • Ironman
    Ironman Member Posts: 7,855
    edited December 2015
    If you blow in the pipe hard enough with the valve closed, it should pop right back out. ;)
    I did the same thing in a blind spot on an 1 1/4" line a few years ago.
    Bob Boan
  • SWEI
    SWEI Member Posts: 7,348
    I think your pump may be a tad oversized.
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    They technically could send you a new joint if someone just took it off the assembly line. They have the technology, they can rebuild it to be better than it is.
    cell # 413-841-6726
  • bob eck
    bob eck Member Posts: 930
    Did it come out of the box this way? It makes me mad when that happens!
  • Harvey Ramer
    Wrong size jaws. The "Waste of Haste".
    All the comments made me chuckle.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,005
    Harvey; Takes a big man to use his mistake as a teaching tool for all to see! Any chance of getting a replacement brass end for that flange or is it best used as a training tool/paper weight? Thanks!
    Yours, Larry
