Whoops!
Harvey Ramer
Member Posts: 2,281
Think I can get a warranty on this? I swear I had my hands in my pockets and was just standing there when it happened.
Or maybe I could go with, the pump sucked it flat? lol
3
wrong size jaws?0
A venturi style iso-flange, nice invention!Bob "hot rod" Rohr
Does it whistle when you blow on it? It's a stocking stuffer!!!0
No problem, that'll buff out.All Steamed Up, Inc.
Consulting1 -
lol! nothing a bit of solder won't fix0
If you blow in the pipe hard enough with the valve closed, it should pop right back out.
I did the same thing in a blind spot on an 1 1/4" line a few years ago.Bob Boan
I think your pump may be a tad oversized.0
They technically could send you a new joint if someone just took it off the assembly line. They have the technology, they can rebuild it to be better than it is.Cost is what you spend , value is what you get.
cell # 413-841-6726
Did it come out of the box this way? It makes me mad when that happens!0
Harvey; Takes a big man to use his mistake as a teaching tool for all to see! Any chance of getting a replacement brass end for that flange or is it best used as a training tool/paper weight? Thanks!
Yours, Larry0
- 87.1K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 996 Plumbing
- 391 Solar
- 55 Water Quality
