dual manometer
Paul_69
Member Posts: 251
in Gas Heating
I have a digital dual manometer and has hoses and fittings for checking gas valves.the taps on manometer and hoses are a little smaller than pressure switch hoses on gas furnaces. Is there a way to hook this meter to dothat as this is why I bought it, to do both. Thx
You can usually find universal tubing couplers at hardware stores. They are stepped so you can connect different hose sizes together."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Or at auto parts stores. They usually have a bigger selection.
Without hoses and connections, modern automobiles can't operate.0 -
Thx alot guys0
Most meters have 1/4" hoses on them. 5/16" hoses seal to most gas valves.
a 1/4" x 5/16" barb coupler and a foot of 5/16" hose will do the trick.0 -
Try a fish tank store they all kinds of tubing and adapters that is were I get mine.0
Nice Tim. They do have "T's for attaching with different tubing.0
