asbestos on steam pipes
GTD
Member Posts: 31
I do not want to remove the asbestos on the pipes just to cover over it.
Uhm... sounds good?0
You may not gave a choice. If WE touch it, in some Jurisdictions, we own it and have to have it properly removed. I think you can cover small amounts. Not 50 uncovered fittings, with the cloth hanging off.
There's never enough time to do it right. Buy always time for someone else to do it over.0 -
I have had good success using plaster impregnated gauze -- the kind doctors use to make casts -- to wrap and encapsulate the asbestos. The gauze has to be wet, but not soggy, and two layers makes a nice tight encapsulation. I the asbestos is dry, it should be sprayed to moist.
You do own the result; there's still asbestos under ther. This isn't remediation, but does eliminate the hazard unless someone has to work on the pipe. The property may not be salable without later remediation, but doing this doesn't make remediation any harder.Br. Jamie, osb
If it's not crumbling, use some light canvas, or cheese cloth then coat it with Childers mastic 11, done deal, nicely encapsulated and will last a long time.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
The plaster cast trick is the best. Cheap and easy to find. And when you want to get it off, all you need is one of those Fein Tool osculating wonder tools that are the rage.
If you've ever has a limb cast because of a broken bone, you know how slick they are.
I've had more leg casts on than I care to think about.0 -
Where can a layman purchase that cast material?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
