Plastic Gas Line Question
A riser. It’s called a riser.
Bob Boan
Yp, but is there a certain kind of riser that is for being encased in concrete?
If it is an exterior slab, just a piece of pvc pipe will work. Inside it needs to be a sealed sleeve and vented
Check the code for your area, should be a section on gas piping, and underground.
Living the hydronic dream0 -
FYI. Be careful..doing any work on Natural Gas or LP is strictly regulated. This is not a DIY project. Mad Dog
The part about sealing and venting the sleeve I think only applies to the building not the generator slab. At the house come through the sill. The place you buy the plastic pipe will have the risers.
Some refer to them as "Meter risers"
