Graffiti on the Mitsubishi
if you don’t see these designations written all over the place, that’s not good. The next guy needs to know what you did and how long the lines are, how much you added. This system gets an 8 1/2 pound drink of juice.
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
PC7060SuperTechMad Dog_2Ironman
    pecmsg Member Posts: 7,359
    nice
    I use a label machine but that works!
    GWHotanCool
  • GW
    GW Member Posts: 5,211
    a label machine- very neat 💯💯💯🛠️🛠️🛠️
    Gary Wilson
    Northampton, MA
    gary@wilsonph.com
    Steamhead Member Posts: 18,753
    edited June 2024
    I do the same thing on oil burners- I list the nozzle type and capacity, the pump pressure and anything else like using a larger static plate (which we do on quite a few retrofitted Becketts to get a better air pattern and better efficiency on a hollow nozzle), using an old-school Dymo labelmaker.
    Consulting
    GWMad Dog_2
  • PC7060
    PC7060 Member Posts: 1,859
    documentation is the hallmark of a true professional
    GWWMno57
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,694
    I hate when you see a brand new electric panel and you don't know what powers what....Mad Dog
    GWPC7060Alan (California Radiant) ForbesGGross
  • DCContrarian
    DCContrarian Member Posts: 1,524
    Of course, a 50-year-old unlabeled panel is worse. Brand new you can assume there was some method to it.
  • ratio
    ratio Member Posts: 4,278
    From what I've seen, the method is often "eenie meenie miny moe".
    To add topical information, I usually show my maths on the cover as well, it being to hand when I'm ciphering up the charge adder.
  • PC7060
    edited June 2024
    Noting the drawing number and approving PE‘s name is good practice when performing structural alterations. Makes the inspection go much quicker.
    GW
  • John Abbott
    John Abbott Member Posts: 362
    Documentation is as was said O the mark of a professional. Back in the day I did a lot of High end radiant multipal water temps, injection mixing based on outdoor reset ti was state of the art for the day. I always left a clip board on the radiant panel with all the water temps loop lengths,I & O manuals for controls etc. One homeowner called me 17 years later in the dead of a NH winter because he couldn't heat parts of his house comfortably.I went over and took a look. The homeowner upon questioning said his oil burner technition said the water temperatures were wrong so he reset them. I retrieved my clipboard.looked up the temps and reseet the injection mixing controls and in 15 minutes all was fine. My $2 clipboard saved a lot of hassle.
    PC7060GW
  • RobertK
    RobertK Member Posts: 7
    There's nothing like a good paper trail.
    "KNOWLEDGE IS POWER, KNOWLEDGE SHARED IS POWER MULTIPLIED" -Robert Boyce
    GW
