Fixture Calculator, you need to use this!
hot_rod
hot_rod Member Posts: 25,302
If you do plumbing work and size equipment and piping, download the free updated calculator is a much needed revision to the 80 year old Hunters Tables and greatly reduces piping size, PRV, mix valves, etc.
Almost on a daily basis we get calls about misbehaving TMV. Most often the valve is over sized or grossly overside and cannot regulate properly.
Don't size any control valve by the pipe it will connect to :) Use tables and manufacturers charts and Cv numbers.
https://www.iapmo.org/water-demand-calculator/
ZmanratioSteve MinnichBigRobErin Holohan Haskell
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,785
    hot rod Thanks that's awesome
    Ray Wohlfarth
    Boiler Lessons
    Jamie Hall Member Posts: 26,148
    Wish I'd had that back in the day!
