Fixture Calculator, you need to use this!
hot_rod
Member Posts: 22,028
If you do plumbing work and size equipment and piping, download the free updated calculator is a much needed revision to the 80 year old Hunters Tables and greatly reduces piping size, PRV, mix valves, etc.
Almost on a daily basis we get calls about misbehaving TMV. Most often the valve is over sized or grossly overside and cannot regulate properly.
Don't size any control valve by the pipe it will connect to Use tables and manufacturers charts and Cv numbers.
https://www.iapmo.org/water-demand-calculator/
Wish I'd had that back in the day!Br. Jamie, osb
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 879 Plumbing
- 5.9K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 58 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
