Thermostat options for ducted Mitsubishi systems?
I am in the process of getting a ducted Mitsubishi mini split system (3 indoor/2 outdoor) installed and I can't quite decide on the correct thermostats to use with the system.
I've had Nest for ~10 yrs and I am a little concerned about spending a fair amount of $$$ for Mitsubishi's proprietary system (Kumo) because despite being expensive it looks like tech from 10+ yrs ago.
Do I have any other options if I want a WIFI-connected thermostat that won't negatively impact the Mitsubishi's efficiency?
FWIW - It's my understanding that the Nest isn't really designed for these type of systems or else I'd stick with it.
  • Ironman
    Ironman Member Posts: 7,903
    edited April 2021
    The Nest is for the birds and should never be used with any modulating equipment.
    Mitsubishi has an add on module which can be used to connect any standard thermostat to its AHUs. The thermostat MUST be setup for conventional heat/cool even though the Mitsi is a heat pump. You don't need the Kumo. You'll need a module for each indoor unit.
    Bob Boan
  • ratio
    ratio Member Posts: 4,236
    You can find more information about the Mitsubishi thermostat interface at http://mylinkdrive.com/USA/Controls/InputOutput_Modules/Thermostat_Interface_for_Module/PAC_US444CN_1?product.
    NB: I have been told that you loose quite a bit of the mini split's efficiency by using this interface.
  • Aston01
    Aston01 Member Posts: 3
    I don't disagree. The problem is there isn't an obvious front runner in the situation so we're left with the second-tier options.
    pecmsg Member Posts: 7,064
    Aston01 said:
    The Nest is for the birds and should never be used with any modulating equipment. Mitsubishi has an add on module which can be used to connect any standard thermostat to its AHUs. The thermostat MUST be setup for conventional heat/cool even though the Mitsi is a heat pump. You don't need the Kumo. You'll need a module for each indoor unit.
    Yes
    Mitsubishi
