Are there any thermostats that indicate when they're calling for heat?
My Honeywell VisionPro tells me when the heat is on.--NBC0
The most basic Honeywell Focus PRO 5000 has nice large numbers. Shows actual temp and temp setting. Say "heat on" when calling. You hear a nice little "click" when going on or off. Backlight when you touch any button.
Does not need C wire but advisable. Get the large screen one.
TH5110D1022
I have 5 in my house.
SupplyHouse.com0 -
I'm finding that a lot of digital thermostats actually do this, but they never list it as a "feature," so it's hard to shop for the right one. It'd be really nice if the mechanical ones could do it, but so far I haven't found one. I like the simplicity of the T87K, but, like I said, I don't like going downstairs to see if the boiler is running.Just another DIYer | King of Prussia, PA
On my Lux thermostat, the flame indicator icon on the thermostat flashes while running. How exactly are looking to be notified?, on the thermostat, notified on your smart phone, flashing red lights......0
Can you give me one you're not using? How many boilers do you have anyway?JUGHNE said:I have 5 in my house.
Just a little indicator on the display would be fine. There's no flame icon on mine. It does tell me what time it is though. Like I really need that.rlev11 said:On my Lux thermostat, the flame indicator icon on the thermostat flashes while running. How exactly are looking to be notified?, on the thermostat, notified on your smart phone, flashing red lights......
I'm using a Lux TX9600TS0
One ModCon, various zones. 2 of them also run AC's.
They are all employed at the moment.
Might have 1-2 on the shelf.
They will also do 1 CPH, just put one on a steamer.0 -
Mine is a TX1500b.Just another DIYer | King of Prussia, PA
The old 80's white rodgers programmable tstats had a huge red light on them when they were calling. My honewell chronotherm 4 or so has a flame and snowflake icon0
Mine says "heat" or "cool," but that only tells you which position the system switch is in. In case you forget. I guess. Not that I would ever have any reason to switch it to "cool."Just another DIYer | King of Prussia, PA
My ancient 80s Honeywell indicates it with a "heat on" or similar.
but I strung some thermostat wire to my living room with a red 24v LED on it so I can know while sitting on the couch.NJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
As you set up the HW Focus PRO series you eliminate any reference to AC and fan on the screen.
Also you can set max heating temp points and min cool temps (if used). Very handy for busy fingers. Most people do not know how to change those settings without the book. (wife included)
Just checked SupplyHouse, don't see that model there.0 -
the simplest non prog heat only thermostat would be this one
https://www.supplyhouse.com/Honeywell-TH1100DV1000-PRO-1000-Non-Programmable-Heat-Only-Vertical-Thermostat.
I was thinking of doing the same thing.ethicalpaul said:My ancient 80s Honeywell indicates it with a "heat on" or similar.
but I strung some thermostat wire to my living room with a red 24v LED on it so I can know while sitting on the couch.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-241 -
That one's on my short list, but I kinda like this one better: https://www.supplyhouse.com/Honeywell-T8775A1009-1-Heat-Stage-Digital-Round-Thermostat-Premier-White-4091000-pLe John said:the simplest non prog heat only thermostat would be this one
You could always jam an LED and a resistor in the base of any t-stat and poke it through a hole you drill in the side.0
I'm fascinated why you're fascinated.
Won't you just know whether or not you're comfortable?
And just because the thermostat shows a pretty flame or gives an audible click, it doesn't mean the berler ain't broke.0 -
Unless I’m cold I don’t look at the t-stat!0
Knowledge is power!
Not that knowing if the boiler is on or off is very much power, I think that @Hap_Hazzard needs to know if the heater is on or off so he can know if he is comfortable or not.
I have a customer that tells me how many minutes the oil burner operates. She has a logbook that goes back 20+ years... and she knows whether she is comfortable or not by how short the cycles are. She is 83-yrs old. The logbook started after her husband died.Edward Young Retired
1 -
It's not whether I'm comfortable. I need to know if I can tell my wife the heat's on when she tells me she's cold. It's also good to know when the heat comes on if you want to re-check your venting, or if you want to go outside and clock the meter. It just seems like a pretty basic piece of information a thermostat ought to share with the user.Just another DIYer | King of Prussia, PA
My Honeywell RTH6450 has a heat on in the display to tell me the boiler is firing. This is one of the cheaper units in their line so IU'd say almost any Honeywell with a display has this feature.
3PSI gauge0 -
I think whoever bought this LUX just made a very bad choice. It has a lot of features that aren't needed and it lacks one that's pretty basic. And now it's getting fussy, so I have to make sure it's still on whenever I touch it. I think the contacts are failing.Just another DIYer | King of Prussia, PA
Cheer up. My main thermostat is a pretty simple programmable Honeywell, and it has a cute little flame icon to tell me that it thinks Cedric should be working. But... I can hear Cedric from most of the main floor. Very comforting. And at my age, "too warm" or "too cold" is pretty subjective, and has very little to do with what the thermometer says...Br. Jamie, osb
I can't hear my boiler from upstairs. I sometimes hear the relay in the thermostat click, but if I miss it, I have to go downstairs and look for the blue glow coming from the bottom of the boiler.Just another DIYer | King of Prussia, PA
Venstar. They have a green or red light depending on mode enabled.
Used to be the Totaline line of tstats.0 -
you can really end this statement right here "I think whoever bought this LUX just made a very bad choice."
Actually i have one that controls the separate zone in my bedroom that replaced an off brand home depot t-stat many years ago that was originally bought to control a contactor connected to my window air conditioner when i lived in an apartment.
It has "switches" that consist of those little spring domes that sit over the traces on the circuit board, i had to take it apart and put some deoxit on the up/down buttons recently.0 -
A red light would be great, but it looks like they don't make a single heat only thermostat.Just another DIYer | King of Prussia, PA
My ecobee shows a small flame while heating and snowflake during cooling, and a fan. Ecobee is a mixed bag. I like somethings, and it's definitely better than nest, but I don't like the fixed differential control.
Honeywell stats (even cheap ones) have better virtual anticipator logic that keeps you house closer to setpoint.0 -
Yeah you're probably right about that. But there's a good chance that you can program the cool out, on many stats you can , and make it a single heat-only thermostat.
That one is also a programmable which you sound like you probably don't want .
You could check with them and see about a non-programmable.
I really liked those old Total Line 0-100 thermostats, witch this is basically a copy of.
I had to replace a couple of the old Totaline thermostats recently ( I did not install them however, their custodian did ) and called Venstar to find out if it was a direct swap onto the old sub base. It is , they were easy to get hold of for what that's worth.0 -
Honeywell T4. Shows heat call and has adjustable cycle rate, great for steam. Easy. About $55 at Supplyhouse.com
- 119 Geothermal
- 394 Solar
