Installing Hartford Loop on WM EG-55 steam boiler
2»
  • EdwinD
    EdwinD Member Posts: 159
    Fred said:
    @EdwinD , Yes, the equalizer will be nearly as hot as your header and steam mains. That heat will transfer to the Hartford loop. It is normal! Enjoy!
    @Fred Thanks! Great! I'm excited for the arriving seasonal cold.
    Weil-McLain EG55 2 pipe Vapor System
    OP Pressure .10 -.25 oz
    8-Way Boiler Water Treatment
    Barnes & Jones Big Mouth Vents
  • ChrisJ
    ChrisJ Member Posts: 17,664
    > @EdwinD said:
    > (Quote)
    @EdwinD did you watch the video I posted?
    It should answer your question completely.
    EdwinD
  • EdwinD
    edited September 2019
    ChrisJ said:
    > @EdwinD said:
    > (Quote)
    @ChrisJ Thanks. Yes I watched the video. It doesn't apply to my concern.
    ethicalpaulChrisJ
  • ChrisJ
    EdwinD said:
    ChrisJ said:
    > @EdwinD said:
    > (Quote)
    The video showed you exactly what is taking place to help you understand what is going on.
    It applies directly to your concern. I explained you have near boiling water dumping down the equalizer. You didn't understand what I meant and that video shows what is going on.
    This explains why it's hot and that it is normal.
    ethicalpaulEdwinD
  • EdwinD
    edited February 2022
    Couple notes. After adding Hartford loop and replacing near boiler piping according to Weil-McLain specs
    1) Operating pressure running at 0.00 to 0.5 oz.
    2) Condensate return is much better - after boiler shuts off when desired temperature is reached, condensate returns to proper sight glass levels in about 10 min.
    3) from cold water, all 11 rads receiving full heat in approx. 17-18 min. I guess that's pretty good...better than before
    Thanks for all your help
  • EdwinD
    edited December 2019
    Final configuration; sincere thanks to all for your assistance.
  • clammy
    clammy Member Posts: 3,260
    Great job good to hear you got it all together and it’s running properly peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
    EdwinD
  • EdwinD
    Thanks! @clammy For a novice like myself, putting this together was like going back to school.
    At first I was very skeptical about undertaking the task. But with you guys help, you encouraged me to forge ahead and I will be forever thankful!
  • SeanBeans
    SeanBeans Member Posts: 525
    @EdwinD good job. Not too hard but not easy eh?
    EdwinD
  • EdwinD
    @SeanBeans Thanks! You said it perfectly! Not too hard, but not easy.
  • EdwinD
    edited October 2020
    Alternative use for automobile jack stands, a long run of wet return piping needed support. Works well.
  • EdwinD
    edited March 2023
    Since completing this project in 2019, I added some improvements in 2022 before the heating season began. THANKS @clammy @Fred @JUGHNE @ethicalpaul @Canucker @Jamie Hall @ChrisJ @EBEBRATT-Ed @Steamhead @Gordo @SeanBeans @mikeg2015 for your advice and walking a mere layman thru this project.
    1) Added new gas valve and using a manometer checked intake pressure and adjusted manifold pressure (old valve - pilot light hold-down button spring broke)
    Based on your input, changes were made:
    2) Added shutoff valve to Hartford loop riser
    3) Added union to wet return.
