2.5 ton 16 seer heat pump needed
zepfan
Member Posts: 464
Does anyone else besides Goodman make a 16 seer 2.5 ton heat pump that can be paired with a 17.5” wide AHU to get 16 seer. Any suggestions would be much appreciated. Thanks to all
Trane XR15 offers a 2.5 ton that will get up to 16 SEER depending on the A/H coil. If this is related to your other thread with the TXV, I dont believe you'll achieve that rating with a 17.5" cabinet and (converted) R22 evap.
I would tell your client you can do anything if they have the $$. Its the round hole square peg syndrome.0 -
thanks for the response, this is a different job then the one that needs the r22 valve0
Carrier.0
Individual components do not have SEER ratings!
To get 16 SEER it has to be matched with there coil, air handler and have an AHRI #.0 -
Look at BOSCH, super crazy numbers with just a coil and outdoor, furnace doesn’t matter. They have a 17” coil.
You need 16 seer———-rebate job? Massachusetts?0 -
ComfortStar makes an adapter to use one of their mini split condensers or heat pumps with any indoor coil. It's in their catalog, but I can't seem to find it on their website for some reason.
Johnstone hawks them around here, and can get information about them; but they've been non-responsive to my emails. FWIW.
1
- 125 Chimneys & Flues
- 19 Recall Announcements
