Peerless repipe
Dave0176
Dave0176 Member Posts: 1,178
edited May 2019 in Strictly Steam
Repiping a 63-03 and down firing it to a 63-03L. Oversized, terrible piping, and copper to boot. Not a problem for us.....
DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
NJ Master HVACR Lic# 4630
I cannot force people to spend money, I can only suggest how to spend it wisely.......
IronmanChrisJ
  • Motorapido
    Motorapido Member Posts: 314
    What did you do to down fire it? I didn't think that was an approved option for that peerless. I have a 50 percent oversize peerless that I'd like to down fire.
    ethicalpaul Member Posts: 8,863
    edited May 2019
    You can go down from the standard size to the “L” variant (or vice versa) I believe with a conversion kit that Peerless sells for their 63 line.
    Beautiful dual supply drop on that little guy, Dave!
    Did you get the size pretty close? What was the radiated EDR?
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,604
    edited May 2019
    Peerless makes their gas boilers with option of using one of two burner trays. The 63-03 and the 63-03L are the same boiler with different sized burner trays. Weil Mclain does the same thing.
  • Dave0176
    The only thing different is the burner manifold. 63-03 is tapped 4 burners and the L is tapped with 3.
  • Fred
    Fred Member Posts: 8,542
    Nice!
  • STEAM DOCTOR
    The boiler manual does list a different part number for the flue collector. 63-03 is 50281. 63-03L is 50282. Not sure if there is an actual difference. The WM boilers have different draft hoods for same sized boilers with different manifolds
  • Intplm.
    Intplm. Member Posts: 3,033
    Lookin Good !
  • Bio
    Bio Member Posts: 279
    Really like the boiler header to main reducing elbow, nice looking job
  • Dave0176
    edited June 2019
    Finally got back and finished this job. We also ran a new main into the new extension on the home with two more radiators that the AC guy said couldn’t be done without high expenses. :#
    Anyway forgot to snap pics of all the new stuff. Spent half a day in a crawl space running pipe. It’s all part of the job....... Also the chimney was eliminated during the renovation so they concocted this long flue run, I don’t like it but it’s what I had to work with. Also sent the cycle guard LWCO to the scrap yard. :D
  • BillyO
    BillyO Member Posts: 277
    BEATIFUL JOB!!! High gloss black rustoleum on that near boiler piping would look pretty
  • wz25
    wz25 Member Posts: 24
    Yes, but then the insulation would have covered it all :)
    ethicalpaulSeanBeans
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    What size are those risers, 2" or 2½"?
  • wz25
    2" risers
    Hap_Hazzard
