Asbestos removal
Bob_G
Bob_G Member Posts: 6
We need to have asbestos removed from our steam piping in order to be repaired/replaced. I am based in NJ, any recommendations?
    EBEBRATT-Ed Member Posts: 19,583
    @Bob_G
    Best way is to call an asbestos abatement company. I know that cost $$$
    It may or may not be legal in your state to remove it yourself. You need proper PP mask, wet down the stuff and remove it wet. It's a question if you want to take on the liability and the exposure risk for you and your family
    also, if the insulation is not damaged there is no need to remove it. It can be cleaned and encapsulated. It's only dangerous when broken friable or loose
  • Leonard
    Leonard Member Posts: 903
    edited April 2019
    Many years ago we added 6 inches of pink fiberglass insulation under floor boards of unfinished attic. The old and new insulation made a lot of dust that got thru paper particle masks and was picky on our hands. And there was ant poison powder on floor boards.
    So we set up 5 large window box fans in windows and made a hurricane thru attic to exhaust all dust outside so we would not breath it. Worked very well.
    Also made large long air ducts from large cardboard and duct tape to duct fresh breathing air where we wanted it deep in building where were no windows.
    Worked well, But that is likely not legal for asbestos. Think they use special HEPA filter fans. Besides some asbestos might settle out on surfaces. We vacuumed whole attic afterwards with shop vac hanging out attic window , next to exhaust fan hurricane. But neighbors were not close by.
    pecmsg Member Posts: 6,773
    The state has a list of Licensed and insured contractors only use them!
  • Intplm.
    Intplm. Member Posts: 2,831
    The steam piping needs to be replaced? If you are having a contractor do it. Ask them if they do the asbestos removal. Or ask who they use.
    ethicalpaul Member Posts: 8,161
    All great advice. I'm sure having a certificate that asbestos was removed properly at the end that you'll be able to save and show to eventual prospective purchasers is valuable too.
    Jamie Hall Member Posts: 26,837
    Looking back at the OP''s original comment leads me to wonder... why is the steam piping being repaired or replaced?
