Nothing to do with steam heating
Steamhead
Steamhead Member Posts: 18,617
but I found this and thought it worth sharing. Who says steam is dead?
https://www.youtube.com/watch?v=RU9uEwSGp9M
Consulting
    Jamie Hall Member Posts: 27,506
    And the 8014 (the Big Boy) has passed her hydrostatic test (now that is higher pressure -- 375 psi) and will be on the road by May!
  • KC_Jones
    KC_Jones Member Posts: 5,936
    611 is going to be in Strasburg PA in the fall, going to do the start up tour and ride behind it. 1309 will be up and running in the summer/fall in Cumberland MD.
    2014 Weil Mclain EG-40
  • JUGHNE
    JUGHNE Member Posts: 11,591
    The steamer had the advantage that the freighter couplings were pulled tight from being stuck on the hill.
    Push the back car first 1", then 2 cars another 1" etc.
    Still one steamer did the job that they sent 3 diesels out to do originally.
    Did you happen to note the wheel slip near the beginning of the clip? The old girl was giving at all she had -- and the engineer had her well in hand.
    Alan (California Radiant) ForbesDave in QCA
  • Leon82
    Leon82 Member Posts: 681
    I think they make them tow the diesel for regenerative braking.
    Actually, only one of the Diesels broke down, but that was enough to stall the train. The video doesn't say, but I understand locomotive engineers will approach a hill as fast as they can so momentum will help carry the train over the top. Since the train was stalled on the hill, with no chance for momentum, this makes 844's work that much more impressive.
    One of the YouTube commenters says these locomotives are used to haul revenue freight when they are being moved from place to place- they never deadhead (run them without actually hauling something) them. This probably helps justify their upkeep, and also keeps the knowledge alive of just how to run these things. Kind of like what we're doing here.
    Consulting
  • JUGHNE
    One "Car Talk" puzzler was why a particular train needed more cars attached, that is a longer train, to make it thru rolling hills?
    As it was climbing the second hill, part of the cars were pushing it as they came down the first hill.
    Usually had to wait for a week for the answer. ;)
  • Fred
    Fred Member Posts: 8,542
    Wow, impressive!
    Controlling slack action in the train in those situations is a fine art -- and where the men really get separated from the wannabes on the throttle.
  • JUGHNE
    As a kid when we still had trains running, I wondered about the bang-bang-bang all the way back to the end of the train.
    Learned later they back up before going ahead to gain that slack.
  • Leon82
    edited April 2019
    There's a video on YouTube where the wheel slip became uncontrolled and spun itself into destruction. I believe the engineer was injured from one of the control levers whipping
    https://youtu.be/YjsNbzg1UaI
  • Dave0176
    Dave0176 Member Posts: 1,178
    edited April 2019
    Here’s a good one.... UP Challenger 3985 a 4-6-6-4 steamer pulling a 143 double stack cars up Archer hill at 45 mph all by itself.
    https://youtu.be/XhgHrDbN4EU
    DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
    NJ Master HVACR Lic# 4630
    I cannot force people to spend money, I can only suggest how to spend it wisely.......
    ethicalpaul Member Posts: 8,922
    There was another one once that was about the "slack action" too. Something like "why can't you start a train when it's in its stretched state" (but described way better than that)
    The problem of starting a long train was much worse in the bad old days of brass journal bearings -- the static friction of the bearings was much higher than the rolling friction, and one did have to put in the slack and start the train car by car. It's much less of a problem now with roller bearings. Control of slack action -- as well as draught gear forces -- is one of the reasons why distributed power in long trans is so popular. Most railroads which operate long trains take a great deal of car in marshalling the cars and distributed power, so that severe slack action is minimized.
  • ChrisJ
    ChrisJ Member Posts: 17,480
    Are you sure about this?
    Do you have a page about it? My boss wants to go see it (Big Boy, not the page)
    ChrisJ
  • KC_Jones
    @ChrisJ tell your boss about this one too, they had the boiler steamed up back in October and are selling tickets for July. Not quite a Big Boy, but still an articulated and very cool.
    https://westernmarylandscenicrailroad.blogspot.com/2018/10/western-maryland-scenic1309-reaches.html?fbclid=IwAR3V6WFakt7Hwst8-_1ehfywKob2e-4u5wxXwGuVn8TkTvpE-T9r6s0Sc9M
    https://www.wmsr.com/
    My parents already bought tickets and taking my son along.
    ChrisJ
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    I grew up in the little Iowa town of Mt. Pleasant, home of Midwest Old Threshers, "a steam and farm show" Permanently on the grounds are a collection of narrow gauge steam trains. This one, is very unique with 3 vertical cyclindes on one side, like by a drive shaft and pinion gears to ALL wheels on the engine and the fuel car too. https://www.youtube.com/watch?v=0pMVKQd0jwM
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • egansen
    egansen Member Posts: 31
    Dave, I rode in the cab of the shay at Mt. Pleasant when it was there. It is quite different than riding in a conventional locomotive. It is now out west some where.
    I used to volunteer on the steam department at the Boone and Scenic Valley in Boone, Iowa. We have a 2-8-2 mikado number JS8419. It was a thrill to get the highball from the conductor, whistle off, and listen as 195psi. of superheated steam bring a locomotive to life as it worked it's way up a 1% grade.
    Dave in QCA
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,727
    I think I can. I think I can. I think I can. I think I can.
    Retired and loving it.
    Dave in QCAMikeAmann
  • Jean-David Beyer
    Jean-David Beyer Member Posts: 2,666
    Those locomotives are called Shay.
    https://en.wikipedia.org/wiki/Shay_locomotive
  • Dave in QCA
    Yes, and they are only capable of slow speeds.
    But they do make an awful fuss while they're doing it!
  • Canucker
    Canucker Member Posts: 723
    Sounds like one of the guys I work with...
    You can have it good, fast or cheap. Pick two
    Dave in QCAratioMikeAmann
  • Lard
    Lard Member Posts: 115
    Many, many of those Shays were made in my hometown, Lima Ohio. Several of my relatives worked at the Lima Locomotive Works “back in the day” so I grew up around these awesome steamers as the old farts and my father sat around talking about them. The Shays were bevel gear drive/set up for insane torque rather than speed and used primarily for logging and mining. Properly configured, they could climb a 6% grade fully loaded. The simplicity and low speed of the drivetrain means quite a few are still going. They were sent as far away as Australia if I remember right.
    Around here, the Nickel Plate #765 2-8-4 Lima “Berkshire” is based in New Haven, Indiana. Shortly after it was steamed up for the first time after (another) restoration, my brother actually got to man the throttle and take it for a short spin. There are pictures somewhere of my brother and I as little runts standing next to it when it was having work done at its birthplace in Lima 30 years ago.
    ethicalpaulCLamb
    Very cool, @Lard! I grew up not far from Lima in extreme southern Michigan, just across the border from Pioneer OH
    UP #4014 "Big Boy" this time:
    https://www.youtube.com/watch?v=8vLWBP-ehOo
    Consulting
    JUGHNE
  • JUGHNE
    Search 4014 here on the wall and there is more story of this year's trip of the 4014.
  • CLamb
    CLamb Member Posts: 348
    The Rough & Tumble Engineers Historical Association in Kinzers, PA annual show is coming up the 16th-19th. It includes many moving and stationary steam engines as well as internal combustion engines including the oldest operating internal combustion engine in the Americas. https://roughandtumble.org/viewreference/40/eventschedules
    I've been to that in the past, but won't make it this year- we're just too busy.
    Consulting
