With a heavy heart....
... we bought a house with forced air. Which wifi stat should I go with? I've never gone fancy but will here. Ecobee, nest, salus, something else?
    Jamie Hall Member Posts: 27,582
    My deepest sympathy. If you want the "learning" capabilities and the internet connectivity, both the Ecobee and the Nest are good thermostats and are designed for and work well with forced air. If you don't want the rest of the world in your house, any good programmable thermostat will work -- I happen to prefer Honeywell VisionPros, which come in a variety of flavours, but there are a number of other good makes.
    Hilly
  • JohnNY
    JohnNY Member Posts: 3,393
    Steamhead said:
    Start with a heat loss calculation, then size the boiler. Choose which type and style of radiation you and your significant other want, and size them. Then set the boiler and radiation in place and start running pipe!
    This ˆˆˆˆ.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    Hilly
  • Hilly
    Hilly Member Posts: 429
    @Steamhead can you run that one by my wife. We have NG in the street to that we can tap into. I would very much love to go with a combi mod-con and throw in a pile of radiators.
    Steamhead Member Posts: 18,710
    Just send her a link to this thread.
    Consulting
    CanuckerkcoppSolid_Fuel_Man
    EBEBRATT-Ed Member Posts: 20,481
    @Hilly
    I lived with FA for 18 years, my allergies were rampant. Not to disparage duct cleaning but not so sure that works. And air cleaners and filters are much improved since way back when
    But, with gas available I gotta go with @JohnNY & @Steamhead
    Buy the boiler and a HW coil and put it in the furnace. Keep the cellar door locked at all times. Run with the coil she will think it is still warm air. Get all the mains done. Or better yet put radiant in
    Then give her enough money for a two day shopping trip. buy the time she gets back you will be all done
    Solid_Fuel_Man
  • Hilly
    Does a hydronic coil in an air furnace improve it much? I mean for this home we shouldn't be in it long enough to justify a compete rip out but having oil removed and putting in NG for a boiler with air handler and domestic water would be a better selling feature than the direct fired oil hwt, furnace and oil tank too.
    If you're looking to move fairly soon, I honestly wouldn't put much money into it -- maybe a decent air filter (the stock ones don't usually do much, particularly for allergens) and a fancy thermostat. Most people don't even really notice the heating system, sad to say, so long as the home inspector says it works -- but they do notice the bling.
  • STEVEusaPA
    Take her to a house with radiant heat...she'll want radiant heat
    Ironman
  • Gordy
    Gordy Member Posts: 9,546
    If you came from a water, or steam base system. It won’t take much to convince after living with FHA long enough.
    Solid_Fuel_Man
    Wouldn't bother unless your staying 5 years or more. Getting rid of oil is a selling point if gas is available.
  • kcopp
    kcopp Member Posts: 4,700
    I have purchased 2 homes...both had SHA when I purchased. Ripped it out and installed hydronic BBd in the 1st and panel rads in the second.
