Is this a normal operating condition
hot_rod
hot_rod Member Posts: 27,351
Solid_Fuel_Man
«1
  • Canucker
    Canucker Member Posts: 723
    Dry fire? That's scary looking
    You can have it good, fast or cheap. Pick two
    Gordy1Matthias
  • Gordy
    Gordy Member Posts: 9,546
    As with any hydronic heating question depends :D I’ll bet the radiant heat effect is wonderful on a cold winters day B)
    So what gives? Looks like dry fire.
  • JUGHNE
    JUGHNE Member Posts: 11,548
    It is pretty awesome if you are a 1000 miles away. :o
    1Matthias
  • Rich_49
    Rich_49 Member Posts: 2,785
    You didn't get what you didn't pay for and it will never be what you thought it would .
    732-751-1560
    Rich McGrath 732-581-3833
  • Gordy
    The gas line is a scary proximity to the event. I see the paint isn’t brown yet.
  • Solid_Fuel_Man
    Ah, the large barrel stove with pipes coming out of it! Looks like a nice toasty fire you have sirs! Keep up the good work.
  • Grallert
    Grallert Member Posts: 1,107
    oh jeez that's scary.
    ratio
    Jamie Hall Member Posts: 27,279
    I hope you were using a very long telephoto lens...
    Erin Holohan HaskellCanuckerSolid_Fuel_Man1Matthias
  • 1Matthias
    1Matthias Member Posts: 148
    edited November 2018
    You couldn't get me in that building for any sum, much less close enough to take a photo...
    Solid_Fuel_Man
  • Steve Minnich
    Steve Minnich Member Posts: 2,878
    If I saw that I’d do a 180 and run like hell.
    Steve Minnich
    1MatthiasCanuckerSuperTech
  • Steve Minnich
    Imaging camera with a small target?
    Steve Minnich
  • Solid_Fuel_Man
    I agree, in all seriousness that's one of the scariest things i've ever seen. That has the potential to level that place and possibly more.....
  • Gordy
    The more I look at the photo, I’m starting to think photoshopped. With the flammable items in the foreground, coupled with the fact there should be heat waves distorting objects in the background above the boiler. Also there should be some smoke from the paint burning off.
  • Solid_Fuel_Man
    I thought the same thing, but there seems to be a red reflection off the gas piping. There also looks to be burnt paint, or possibly just the photoshop image overlay too...
  • Gordy
    I think the paint is the overlay of the photoshop attempt. Red hot like that the paint should be scorched on the sides to, and above. Most people would be looking to shut that beast down verses getting a picture :D
  • Gordy
    However there are some real photographers that just make it a priority over 1st steps. Clean your dryer lint.........
    Honey do you have time to call 911? I gotta get a picture of this!
    Canucker
  • HomerJSmith
    HomerJSmith Member Posts: 2,774
    I'll bring the hot dogs if you bring the beer!
  • Solid_Fuel_Man
    I've seen a dryer fire happen, and it ain't pretty! Never ever ever, would I ever put any plastic hose on a dryer either. All hard metal pipe for me after seeing that!
    Gordy
  • ratio
    ratio Member Posts: 4,219
    Unless the camera has good IR filtering, it'll overexpose very hot surfaces. I expect that it wasn't quite so ...visible... to the naked eye.
    That said, with the oxidation that's showing on the very hottest parts, I'd've pulled the fire alarm & called the fire dept as soon as I saw it.
    CLamb
    EBEBRATT-Ed Member Posts: 20,103
    Dryback boiler with refractory damage
  • RayWohlfarth
    RayWohlfarth Member Posts: 1,962
    wow thats scary
    Ray Wohlfarth
    Boiler Lessons
  • Solid_Fuel_Man
    @EBEBRATT-Ed I wondered that as well. If that were the case, it wouldn't present an explosion hazard.
  • Zman
    Zman Member Posts: 7,611
    @hot rod
    You can't just post a pic like that and walk away.
    Did you see this boiler or was it a picture from the internet?
    Albert Einstein
    I got the pic 3rd hand from a wholesaler that knew the service tech on the call. The building was evacuated, seems the fire marshal and boiler operator had different opinions on how to cool the boiler.
    Another tech that saw the pic recognized the boiler as one his company used to service, years back. He has a high pressure boiler operators license in the State and he indicated there is a protocol for cooling down a boiler that has run away like that.
    Must have been 3 safeties failed for that condition, LWC, operating stat and high limit?
    How to cool the boiler? Just shut it off and leave it connected to the system, the load will cool it down. When it has "cooled" as much as possible isolate it.
  • Solid_Fuel_Man
    Is an HRT type boiler a dryback like a scotch-marine? At least all that I've seen are.
    How did they cool the boiler? I'd think simply turning off the burner could allow water to return to the boiler which could still be red hot and end up catastrophic. I'd suspect isolating the boiler and turning off burner would be the safest way. I wouldn't want to be the guy turning those valves, let alone the guy taking the picture. Wow....
  • Mike_Sheppard
    Mike_Sheppard Member Posts: 698
    EDIT: I was given inaccurate information.
    We had a hotel in Maryland where this happened and it was even worse. The boiler didn't blow but the tubes got so hot they started to melt and were "U" shaped. Boiler was a total loss.
    Never stop learning.
    Solid_Fuel_Man
  • kevinj_4
    kevinj_4 Member Posts: 91
    Yes this one was a dry back. The boiler was a steam boiler and it was empty. They shut it off. The feedwater line broke and no water could enter the boiler. The safeties were probably bypasses or failed long before the feedwater line broke.
    There are dryback and wetback scotch marine boilers.
    I was told it was a maintenance guy who shut the boiler off.
    Mike,
    You do not have your facts straight at all on this job. The feed did not break, the pump coupler stripped.
    The controls are not full of mud. In fact the LWCO tested open.
    The backup warrick relay base is melted in the cabinet so it cannot be tested at this time.
    And last a Michigan state trooper at the site shut it down.
  • kevinj_4
    It was an HRT boiler. I talked to the contractor on facebook who is dealing with it. It was a government facility and apparently the insurance and inspectors didn't care about finding out what caused it to happen. I have more pictures of the boiler opened up that I can share later.
    The contractor told me they found nothing jumped out but I'm not sure if I believe that. It had a Warrick probe style low water cut off as well as a McDonnell Miller 150. The only way I see a probe style LWCO not shutting the boiler down is jumping it out. I had a customer that had their LWCO go bad so they had an "electrical engineer" who lived in the building come fix it. He grounded the probe with a jumper. My bet is probe was bypassed and 150 was full of mud.
    Hotrod, you must have got this from Chris.
    Low pressure steam, 2 LWCO. one manual reset.
    Pressure controls mean nothing when you dry fire.
    A lot of wrong information on here!!!!
    The state boiler inspector spent a half day with me, the insurance inspector is coming in this week for second visit.
    We have meetings coming up with the customer, priority was securing the dead boiler and bringing second boiler and heating plant back on line. Then thoroughly testing all the equipment in the plant.
    The state has their own HVAC people and we only go in when.there are issues,
    There is plenty of time to inspect this thing now.
  • kevinj_4
    Mike,
    I am the contractor and I do not do facebook so I do not know where you got this info.
    Your bets are all wrong here, CNA done an internal & the boiler was CSD-1 tested by the state HVAC group in August 2018.
    Float is clean & LWCO was open, warrick base is melted.
    Again this equipment is serviced by the state HVAC people, contractors are only brought in when needed.
  • kevinj_4
    NOT Photoshop, this is real, photo taken by the trooper that shut it down.
  • kevinj_4
    Yep, dump the e-stops and let it cool.
    RPK
    I did get it from Chris, saw him at a training I was doing at Local hall last week.
    I did not get many details, don't want to speculate on the cause, just wanted to share how serious a runaway boiler can be, and look :)
    Hope you get it all worked out, glad it wasn't a more serious event.
  • kevinj_4
    Well, they were very close to a serious event!!!!!!!!
    Some of that computer stuff is melted and the insulation on the back door is completely melted, another hour it may have been real bad.
    The trooper that was onsite noticed the odd smell and went looking for it.
    The boiler is junk. We hope they let us dig in a bit more.
    We had to wait for the state inspector before it could opened.
    Then disconnect it and work on bringing the plant up, now insurance can come in.
    Since the e-stops killed it the gas valves are working, as I said the 150 LWCO tested open and the bowl is clean.
    There was a valid CSD-1 from august & an internal inspection by the insurance inspector so this thing should have been in good shape.
    Nothing is real obvious and nothing is jumped out.
    Did the flame safegard fail?????? It is one item not yet tested due to the process here.
  • kevinj_4
    The gas pipe is brown.
    But they weld on live lines. That is the least on my worries.
    If this boiler would have got a gallon of water it would have been all over.
    Solid_Fuel_Man
  • kevinj_4
    Does this help with your ideas of photoshop???
    Insulation completely melted out.
    Solid_Fuel_ManSuperTech
  • Gordy
    Take it easy. This is the Internet. I don’t believe everything posted until I see proof, especially pictures. Thanks for the proof, and I hope all goes well.
    kcoppDan Foley
  • kevinj_4
    Hey Gord,
    This really ain't take it easy territory. A lot of you are out there throwing stones and the boiler ain't even cooled off yet.
    There are procedures here which I have put above.
    This is a real life-safety event we can all learn from but until we are asked to find the cause it is up to others at this time.
    This is my 4th dry fire and I hope to retire in a few months, the other 3 were cast iron without all safety's built into this boiler.
    Fortunately these things do not happen often.
    This should not have happened since it was tested and & inspected recently & it has 2 LWCO on it.
    The other boiler checked out fine and has the same controls.
    Oh & the plant is online & running fine. Just short 1 boiler.
    GordySolid_Fuel_ManCLamb
  • Solid_Fuel_Man
    @Kevinj thank you for all the info. I'm very interested in the results of the/your investigation.
    I have wired hundreds of burner and boiler controls, would like to learn how this can happen. Welded contacts is the first thing that comes to mind.
    Very scary!
  • kevinj_4
    Very scary!
    No welded contacts found at this point, the 150 ohms open (will not close tho it makes all 3 clicks up & down)
    No shorted wires found so far either.
    You can see in the Warrick (clear case)
    So about the only other thing in the circuit is the flame safegard control. Maybe burner contactor???? But gas should be stopped from safety circuit, e-stop killed it so gas valves were working.
    Lwco should stop power from all of the controls in theory.
    We have to remember this thing was around 2000° so by the time any investigation was started a lot of metal was moving around. We may never see the condition that caused it.
    Just the expansion & contraction may have broke a welded contact.
    Solid_Fuel_Man
