Remote Control Gas Valve?
Kungur
Kungur Posts: 57
Wwondering if such a thing exists?
The application would be for a tri fuel generator that would be situated outside. The generator can be started with a fob. So wondering is there is a NG valve that is able to be activated remotely?
Thanks!
  • ratio
    ratio Posts: 4,351
    Kinda all electric valves can be operated remotely. You'll need to make sure it's rated for natural gas, and sufficient pressure and flow—but I'd imagine anything sized for the line will be big enough. You have a choice of a solenoid valve (all in one) or a ball valve with an actuator. A normally-closed solenoid is probably what you want. With a tri-fuel generator, I would expect it to have provisions to control the valve itself, match the coil voltage.
    Jamie Hall Posts: 28,029
    I don't know about you, but I'd never want to turn a fuel valve on when I wasn't in a position to see what happens when I do…
    dean_specmsg
    EdTheHeaterMan Posts: 13,043
    My gas valve opens as a result of a signal from my thermostat, which is located remotely from the gas valve. The thermostat is in the living room, and the gas valve is in the basement. Does that count?
    My son also has a tri-fuel generator that he can connect to a transfer switch mounted on the outside wall near his electric meter. To get power from the generator, he must engage a switch that disconnects the utility power and allows the generator to supply electricity to selected circuits in his home. There is a natural gas quick-connect fitting, and the generator also has a gasoline tank.
    One interesting thing about that setup is that when operating on natural gas or propane, the generator can only produce 9,000 watts. However, when operating on gasoline, that same generator can produce 15,000 watts.
    Does that mean natural gas is less efficient than a liquid fuel like gasoline?
    And to think, people told him to switch from fuel oil to natural gas to heat his home because it would save him money!
    GGross
    Not a matter of efficiency, @EdTheHeaterMan— it's energy density. There are two types of bonds in fuels — carbon to carbon and carbon to hydrogen. Carbon to carbon releases more energy when broken than carbon to hydrogen — and natural gas gas only carbon to hydrogen (propane has 2 carbon to carbon). Gasolline has 7 (usualy). Diesel typically 10 to 14.
    The natural gas or propane engine isn't less efficient — it's just getting less oomph out of each bang.
    edited 7:47PM
    Interesting @Jamie Hall. What is the cost $$$ per oomph. that is the real measure of efficiency. IMHO.
    That is where the comparison charts come into play
    my favorite is :
    The primary variable is: Om = OOMPH
    One OOMPH (Om) can be converted into dollars, BTUs, kilowatt-hours, horsepower, and several other questionable measurements.
    Master conversion formula
    Where:
    Variable
    Description
    Om
    OOMPH factor
    D
    Dollar coefficient
    B
    BTU multiplier
    K
    Kilowatt-hour factor
    F
    Frustration index
    Z
    Zing factor
