NG Line Depth?
A lot depends on your location. Check with the authority having jurisdiction.
normally there is a table in te code that tells what the depth is depending on things like type of service and if it is located where it will see vehicular traffic and things like that. the codes are available online.
Thanks! I'm going to go at least 18" since I will rent a trencher.
look in your code. it can be 24" in some cases too.
