Would like programmable thermostat for my vapor system
Good evening,
I'd like to replace my old Honeywell TH5110D1006 for one that is programmable. Attached pics show the old Honeywell.
System is a 30's Arco model K vapor system that is running well.
Recommendations?
thanks,
Todd
I'm not sure that setting back a steam system by less than 5°F for at less than 4 hours will yield the fuel savings you're looking for. With smaller setbacks or shorter periods, the savings may be minimal because most of the energy saved during the setback will be used to bring the building back up to temperature.
As a general guideline, you should aim for a setback of at least 5°F for 8 hours or more to realize any meaningful fuel savings.
That said, any thermostat with a programmable timer and a heating mode should do what you need. You may also want to consider a thermostat that uses a C-wire for continuous power, so you won't have to worry about replacing batteries. That may require an additional conductor from the thermostat to the boiler. A 3-wire thermostat cable is the minimum for a thermostat what needs a C wire
Are you looking for internet access for programing using a smart phone or tablet?
If @tmw is who I think he is, his system responds quickly.
I like the Honeywell VisionPro 8000, on which you can set the cycle length to your liking:
https://www.supplyhouse.com/Honeywell-Home-TH8110R1008-VisionPRO-8000-with-RedLINK-technology-Programmable-1H-1C-Touchscreen-Thermostat?_br_psugg_q=vision+pro+80000 -
oh, looking at the old posts it is oil so it would have a 24v primary control that you can probably get a c wire from. looks like @Steamhead worked on it like 15 years ago
Steamhead most certainly tuned it up beautifully all those years ago..
I'm looking more for a nice warm house when I get out of bed in the morning more than fuel savings.
And sure, I can run a c-wire. But changing batteries every year or so is OK for now.
As a matter of course I've always taken the temp down about 10 degrees at about 10:00pm and then bring it back to normal house temp around 7:00 am. But the comment about fuel saving has me thinking. Am I in fact saving fuel? Considering that I'm using all that energy to heat the house up each morning?
And Frank, is there anything that is less high-tech that you like? I don't really need wireless anything. Just simple manual programming.
Anyone have opinions on this one?
I'm not at all averse to spending more money on a better product. Just don't know if I need more than this. Unless one of you guys can tell me why it's great to have wireless control
Thanks in advance for your help.
p.s. re: my post last year about radiators not heating fully. we cleaned the boiler a few months ago. what a difference! still cannot believe how well this 65 yo commercial weil-mclain works…and love these new valves (Mepco SWRF-B) which I install everytime I pull a radiator out to work on this old house..
These are now warm at the return.
I don't think you can get a "C" wire from an oil primary unless I am old and out to lunch.
I don't need wi-fi or anything that requires continuous voltage so batteries are fine.
Another question: I am running 30.15 volts control voltage. Pretty sure my old t-stat is ok between 24-30v, but don't know if a newer t-stat will be happy with that voltage..
That voltage shouldn't be a problem. And that voltage is probably with the transformer unloaded — it may drop when any load is put on it.
@tmw , that VisionPro is commercial-grade, which is why I like it. But the one you linked to is one I have not used, so I can't comment on it. However, it's fairly cheap, and as long as you can set it to 3 cycles per hour or less, it would be worth a try.
Is it best set to 1 cph if that's available?
Once the system responds quickly, 3 should work well.
- 133 Chimneys & Flues
