Steam Pipe Insulation
Hello. I just had an old steam boiler removed and the asbestos along all the pipe runs in the basement. My new steam boiler is being installed in a week, but the contractor that is installing the fiberglass insulation can't start for 8 weeks. That brings us into December. It's mid October now and the heating season is about to start. I saw from the video on the major heat loss. Will the new boiler also be damaged in anyway if I run it before the insulation contractor gets here?
  • SteamNow
    SteamNow Posts: 107
    No it won't be damaged. It may have to run a little longer to heat up the space. Depending on how much insulation there is it may not even be noticeable.
    Owner
    Steamnowrockford.com
    pecmsg Posts: 7,634
    It will be fine.
  • patrykrebisz
    patrykrebisz Posts: 168
    It will be fine BUT... Putting on insulation has to be one of the easiest handy-man jobs.... Maybe it s time to tackle the job yourself? (Just don't disturb the asbestos).
  • posiecki
    posiecki Posts: 15
    Agreed. I was able to get it covered by an energy audit I did with NHSaves. My natural gas utility paid for it.
  • posiecki
    posiecki Posts: 15
    Asbestos has already been completely removed.
    ethicalpaul Posts: 9,075
    There's no danger of damage. The only thing that will happen is the basement will be a little warmer. You might even like it that way, it will tend to warm your floors.
