What is this?
it is off a steam radiator. Boilers are running about 6psi. This crystal like substance is all over steam and condensate pipes everywhere.
Any help? Thanks
    Jamie Hall Posts: 27,805
    First thought — unless you have some kind of air handler system, get the pressure down where it belongs — less than 2 psig, or even lower for some systems.
    Now… that white stuff is from something — probably some kind of dust — in the air. Without doing a chemical analysis it would be quite unwise, in my opinion, to say what. That said, it is very unlikely that it has anything to do with the heat source, just with the movement of air through those grilles.
    pecmsg Posts: 7,542
    radiator or forced air blower?
    Can we get a picture it the unit?
  • iPipefitter
    iPipefitter Posts: 21
    edited 8:21PM
    it is a radiator. The boiler chemicals have been quite high on sulfite lately. The radiator also has a chemical stench coming from it and it’s not leaking. All the steam piping is ran in copper. (Condensate as well) very old plant over 100 years. We have 14” copper steam mains. Also it’s not just the radiators the steam mains also have this build up as well as condensate return lines.
    HVACNUT Posts: 7,682
    edited 8:32PM
    Is that the top of the radiator we see through the grill? It's not a hard connection so I wouldn't think the heat would directly cause whatever that is. Maybe high moisture from venting? Biological growth? Do you know if the grills have been cleaned and it returns? If that's known, how long before it returns?
    I searched snowflake growth on HVAC grill and one of the results was this.
    White mold. Similar?
  • iPipefitter
    when I took a sample of it to send to the lab, it’s very flakey and as soon as I touched it most of it turns into small crystal like particles. Looks like a spider web, but it isn’t. And it isn’t dust, the lab is going to test it tomorrow should get results by the end of the week.
  • iPipefitter
    also, to answer your question hvac nut. We have cleaned the pipe and it’s back the next day. So within 24 hours.
  • Definitely look like some sort of crystalline deposit over dust or mold to me. Seems like something is getting carried along and deposited once it cools down.
    Don't know how expensive it would be to do, but someone with a Mass Spectrometer should be able to help ID the compound or compounds. It could be some sort of sulphate salt or something like that
    iPipefitter
  • iPipefitter
    thank you, it’s also only on the Steam/condensate lines.
  • Can you take a picture of the entire system? I just want to see your 100 year old heating plant. This from someone with a 90 year old system.
    Lifelong Michigander
    -Willie
  • iPipefitter
    I can take a picture of the boiler room. But the plant is massive it’s on over 30 acres. Large steam mains run throughout the inside of the plant.
