Whitworth Threads?
scatgo
scatgo Posts: 102
edited September 18 in THE MAIN WALL
I lost that part of a bleeder valve on a 100-year-old cast iron radiator. I was going to buy a screw at the hardware store and turn it down in my lathe but its not metric or SAE. I don't have a clue if any of the bleeder valves i see for sale with 1/8 or 1/4 NPT will fit and I am scared witless at the ide even trying to remove the old bleed valve because i don't want break anything and make my situation worse. Any body have a clue as to where I can get that part?
    mattmia2 Posts: 18,488
    probably proprietary to whoever made that valve.
    EBEBRATT-Ed Posts: 21,411
    Just take the old bleeder out and replace the whole thing. They seldom break. If they do which is unlikely you just drill and tap it going a size larger if you have to. Most are 1/8" so drill and tap it for 1/4" Ips. But it is not likely to break.
    mattmia2Ironman
    109A_5 Posts: 4,811
    You have a lathe. A properly outfitted Lathe can cut threads. Measure and match. Maybe dabble in the Machinist's Handbook a bit.
    " not metric or SAE " maybe the old USS (United States Standard) or UNC (Unified National Coarse).
    ChrisJMad Dog_2
  • Intplm.
    Intplm. Posts: 3,164
    Many times you do not need a drill if the bleeder threads break off inside. Often, you can set the tap inward and turn it with the broken piece still in the hole.
  • Bspt and bspp fittings are still used I the industry. You could probably find something nominal of mcmaster Carr or something and modify it.
  • It looks a lot like an acme thread and valve stems are an application where acme threads are used.
  • Grallert
    Grallert Posts: 1,255
    With a snuggly fitting wrench the bleeder body should come right out. You could use a torch to heat it up first. If it breaks a reverse twist drill of the correct size will likely remove what's left behind.
  • Pumpguy
    Pumpguy Posts: 818
    edited September 18
    Imperial threads ( Whitworth, and USA threads like SAE, NC, NF, USS, are determined by the number of threads per inch. On the other hand, Metric threads are determined by the number of threads per millimeter.
    Whitworth threads have a 55 degree angle and rounded crests and roots. Metric and our USA threads are of 60 degree angle.
    The best way to determine the pitch of a thread is to use a set of machinist's thread pitch gauges. I frequently use a tap with a known thread pitch as a gauge to determine the pitch of a thread I need to measure.
    Knowing the pitch and the OD of the thread is what's usually needed to determine the actual thread size.
    you can also measure a couple with a micrometer or caliper and divide by the number you measured, then invert if you are using tpi instead of the actual pitch to measure the thread.
    hot_rod Posts: 28,832
    Unusual to see something that diameter with such a coarse thread.
    a 1/4 bolt coarse thread is 20 tpi
    It could be a specific thread cut to give you quick and wide opening
    A 6 point socket is a good way to remove bleeders if it is a hex shape. Brass doesn’t usually seize tight in iron.
    scatgo
