turbo torch tip sizes
Flowing nitrogen is just plain good to do.
I suppose you can go over the top if you work at it a while, but the A2L protocols require it everywhere now, so giving my guys a choice to do it or not will just confuse them. ALL VRF systems require it for the extended warranty & likely the regular warranty. Flowing nitrogen will flush contaminates & moisture out of the lineset, your vac will pull down faster. You have to have the bottle out anyway for the pressure test.
No down side. Except, I guess, toting the bottles up the ladder to the roof. That's hard.
4 -
What size bottles do your guys use? 60s?
pretty sure the manufacturers of r22 equipment required it too
You can also use Co2. We used that with the small aluminum tanks. It holds a lot more gas than a nitrogen tank and a lot less weight.
I use 40 cu ft bottles when I can, 80's when I can't, occasionally 125's, and once a (well, many, sequentially) manifold of 12x 200's.
Not sure about flowing CO₂ during brazing. I'd think that the temperatures may lend themselves to breaking down the CO₂ and then we're back where we started; but I admit to never having actually checked that such is the case. The bottle threads are different, IIRC.
CO2 is an inert gas like nitrogen
Older thread restart.
What size tank do you use with that A32?
Apparently even my A14 is way too big for a B tanks withdrawal rate?
If following the 1/7 rule you can't go over an A5?
I'm really confused now with everyone I see using MC tanks
I don't get it?
Going from memory I guess the reason for not overdrawing is not to pull the acetone out?
To tell the truth I never heard of checking the withdrawal from a B or MC tank.
Your probably technically right but I am not sure anyone ever worried about it.
I used to carry 2 "B"s and 1 "MC" in my van so I could solder or braze.
I had an A-32 and used it some (not a ton) and never had an issue.
But if we were on a job with tons of soldering (and since acetylene prices are $$$) I had a couple of propane turbotorch set ups at the shop because
Propane was so much cheaper and
If we were out of town or in a remote location with no supply house, you couldn't get acetylene, but you could fill a propane tank at a hardware store or home center or steal a barbecue grill tank. And if you had an aluminum propane tank (I forget the size) they weigh 1/2 of what a "B" tank weighs and you get probably twice the fuel out of it
And you can braze with propane but need the right tip because it is not as hot . Most times I would use Oxy Acetylene for brazing unless it was just a few smaller fittings. Regardless of the withdrawal rater you use a lot more with air/acetylene than oxy/acetylene
it is duty cycle too so it is average drawdown rate.
MC bottles are for one or 2 small joints.
b tanks for install.0
- 133 Chimneys & Flues
