turbo torch tip sizes
2»
    pecmsg Member Posts: 7,538
    POE changed all that, as well as mini splits.
    POE is a cleaning solvent, it scrubs the lines clean!
    minis do NOT use filters they use screens. That carbon oxide plugs them
    ChrisJPC7060
  • ratio
    ratio Member Posts: 4,313
    Flowing nitrogen is just plain good to do.
    I suppose you can go over the top if you work at it a while, but the A2L protocols require it everywhere now, so giving my guys a choice to do it or not will just confuse them. ALL VRF systems require it for the extended warranty & likely the regular warranty. Flowing nitrogen will flush contaminates & moisture out of the lineset, your vac will pull down faster. You have to have the bottle out anyway for the pressure test.
    No down side. Except, I guess, toting the bottles up the ladder to the roof. That's hard.
    ChrisJPC7060trivetmanclammy
  • ChrisJ
    ChrisJ Member Posts: 17,669
    mattmia2 Member Posts: 18,091
    pretty sure the manufacturers of r22 equipment required it too
  • Big Ed_4
    Big Ed_4 Member Posts: 3,581
    Back in the days , we flushed the lines with R11 …. :)
    clammy
    EBEBRATT-Ed Member Posts: 21,010
    You can also use Co2. We used that with the small aluminum tanks. It holds a lot more gas than a nitrogen tank and a lot less weight.
  • ChrisJ
  • ratio
    I use 40 cu ft bottles when I can, 80's when I can't, occasionally 125's, and once a (well, many, sequentially) manifold of 12x 200's.
    Not sure about flowing CO₂ during brazing. I'd think that the temperatures may lend themselves to breaking down the CO₂ and then we're back where we started; but I admit to never having actually checked that such is the case. The bottle threads are different, IIRC.
    ChrisJ
    CO2 is an inert gas like nitrogen
  • ChrisJ
    Older thread restart.
    What size tank do you use with that A32?
    Apparently even my A14 is way too big for a B tanks withdrawal rate?
    If following the 1/7 rule you can't go over an A5?
    I'm really confused now with everyone I see using MC tanks
    I don't get it?
    Going from memory I guess the reason for not overdrawing is not to pull the acetone out?
    To tell the truth I never heard of checking the withdrawal from a B or MC tank.
    Your probably technically right but I am not sure anyone ever worried about it.
    I used to carry 2 "B"s and 1 "MC" in my van so I could solder or braze.
    I had an A-32 and used it some (not a ton) and never had an issue.
    But if we were on a job with tons of soldering (and since acetylene prices are $$$) I had a couple of propane turbotorch set ups at the shop because
    Propane was so much cheaper and
    If we were out of town or in a remote location with no supply house, you couldn't get acetylene, but you could fill a propane tank at a hardware store or home center or steal a barbecue grill tank. And if you had an aluminum propane tank (I forget the size) they weigh 1/2 of what a "B" tank weighs and you get probably twice the fuel out of it
    And you can braze with propane but need the right tip because it is not as hot . Most times I would use Oxy Acetylene for brazing unless it was just a few smaller fittings. Regardless of the withdrawal rater you use a lot more with air/acetylene than oxy/acetylene
    it is duty cycle too so it is average drawdown rate.
    MC bottles are for one or 2 small joints.
    b tanks for install.
