Replacing near boiler supply pipes/valves
guzzinerd
guzzinerd Posts: 463
edited August 10 in Strictly Steam
The valves on this loop are in pretty rough shape and have scheduled a plumber to come in and replace them this week:
My question is on the procedure. Is this correct?
1. drain the boiler
2.replace the valves/pipes
3. refill and then fire the boiler to rid of the oxygen
.. or is there a way to not lose the boiler water while replacing those valves?
Thanks
Alex
P.s. just a reminder that I'm in remote new mexico mountains, no steam people nearby
Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
7225.jpg 289.2K
    mattmia2 Posts: 17,994
    depends on how much of an issue refilling it is. you could probably do some things with some jet sweats or plugs to remove things and plug them and only lose a couple gallons but that is more trouble than its worth unless refilling it is difficult.
    Jamie Hall Posts: 27,737
    Steam? Check the water level in the boiler — and lower it just enough to be below those valves. Then shut off the supply and have at it. May I suggest quarter turn ball valves for replacement?
    PC7060
    EBEBRATT-Ed Posts: 20,938
    Your going to have to drain the whole boiler. just drain it and refill when done. Run the burner until it steams and then shut it down.
    guzzinerd
  • guzzinerd
    edited August 11
    Yes, steam. I had a new ball valve replacement, strainer kit and gaskets ready but the thing is a real mess on the inside. Then i found a receipt from the last ball valve replacement dated July of 2005 so I just ordered a new unit (47-2) from Patriot.
