shower drain in an old school building
Grallert
Grallert Member Posts: 1,159
Hi everybody. I'm deep into an interesting shower drain issue. Tasked with replacing a trap for a shower. Without getting long winded I'll put up some pictures as an illustration of what I'm working with. This building is all masonry and this shower trap cast into about 12' of cement. I need to get from a new shower drain and trap into the existing 3"wye. The problem I'm having is a 3" rubber bushing is too big and a 2" is too small. I'm missing something I guess. Any advice would be greatly appreciated.
Displaying IMG_2846.jpeg Displaying IMG_2842.jpeg Displaying IMG_2845.jpeg Displaying IMG_2844.jpeg Displaying IMG_2843.jpeg
    mattmia2 Member Posts: 17,781
    your images are missing but i'm thinking lead and oakum?
  • Grallert
    weird about the images. I think youre right about the lead and oakum which is something ive not ever done I’ll try the images again
    thenks for the reply
  • Grallert
    is that a hub you're looking at? could also try calling fernco or mission and see if they have different size doughnuts. different manufacturers and different weights of ci have different hub sizes.
    you'd need a runner to pour lead on a horizontal joint.
    Grallert
    is there a bomb shelter under that bathroom?
  • Grallert
    I will look around for a different size. My first stop was F W Webb. Second stop was you guys.
    That's the living room below. 12' ceilings. Being renovated. There was a steam condensate leak at a tee in the ceiling/floor along with a roof leak running down a vent in the wall saturating the masonry. This destroyed the ceiling. We thought it was the trap. It was not but in order to find that out I had to dig.
    EBEBRATT-Ed Member Posts: 20,726
    Not a plumber but I looked up the diameter of Ex heavy and service weight CI pipe and hubs and I saw nothing that was 3 1/4".
  • Grallert
    Seems odd. My guess is it's actually 3" or was. I have a bushing marked 3" for SV and POG-3-SW but it's far too large to fit into the hub. Or seems to be. I recognize they are a very tight fit but this really seems excessive.
  • Grallert
    Though I am unable to see if it's extra heavy or service my guess is extra heavy judging by how this building was put together.
    pecmsg Member Posts: 7,386
    that is one thick floor!!!
