Steam radiator section separation mystery
So we recently remodeled our kitchen, which had one tall-ish 7 section single-pipe steam radiator. Our contractor initially removed it and it's been sitting on our back porch (covered) for a couple months. My intention was to get it sand-blasted and powder-coated before reinstall.
However, when I was cleaning it off today, I realized that the top sections appear to be separated? See pictures.
Any idea how this happens? I really don't think it was our contractor, I was there when they removed it and it didn't require much.
What makes this weirder is that we used this radiator for two winters before removal, and it seemed to heat fine. How could it be like this and not be clearly leaking tons of steam into the room?
IMG_6995.jpeg IMG_6996.jpeg IMG_6991.jpeg IMG_6990.jpeg IMG_6992.jpeg IMG_6993.jpeg
    Jamie Hall Posts: 27,906
    Are the nipples between the sections actually damaged? Or is it just that the sections were never pulled together tight in the first place? The sections don't have to be touching, as there are nipples which actually make the connection.
  • orew
    orew Posts: 5
    Actually, I just sorta answered my question, though I'm still curious how this works.
    I just checked 3 other similar working rads in my house (should have done this first), and they are the same way. You can clearly see light between the sections, definitely no nipples, and almost certainly designed this way? (More pics below)
    I'm no steam expert (but I read the Dan Houlihan book), but shouldn't the tops be connected via nipples so the steam can push the air out? Is this some special type of steam radiator.
    House was built in NJ in the 1920's, if that means anything.
  • orew
    orew Posts: 5
    Awesome, thanks for the help!
  • JUGHNE
    JUGHNE Posts: 11,644
    IIWM, I would pressure test it with water before refinishing.
    Your contractor should be able to do this. Use very low pressure.
    EBEBRATT-Ed Posts: 21,169
    If all the other rads look the same I would suspect no issue as it worked before
    Intplm.STEAM DOCTOR
  • STEAM DOCTOR
    STEAM DOCTOR Posts: 2,669
    No worries at all. There are thousands of steam radiators that look exactly like that.
    Mad Dog_2ethicalpaul
