Source for Replacement Swing Check Valve
Hello, does anyone have a source for this three-quarter inch swing check valve? This is for the return section of a two pipe steam system.
The Fairbanks brand is out of business and I can't find this exact one. It's 3/4" NPT, 3" long.
If anybody has new old stock, or an alternative brand with a similar spec, I'd appreciate it. Thank you.
    hot_rod Posts: 28,700
    looks like a basic tee pattern swingcheck. You may need to shop all the brands to find one exactly the same length.
    Watts, Apollo, Milwaukee, Nibco are a few brands. Unless there is audio. On either side, you may need to cut and do so rethreading. So exact length may not be a issue?
  • Larry Weingarten
    Larry Weingarten Posts: 4,210
    Hi, A question, or two… What's wrong with the valve? And have you taken the top off to get a look inside? I've often been able to free up stuck valves by removing the top to get access. 🤔
    Yours, Larry
    rick in Alaska
    As @hot_rod mentioned check valves at least threaded ones do not come in a standard length.
  • Thanks for the replies.
    I'm doing some off-season repairs and preventative maintenance. Specifically replacing some old piping, which this valve falls in the middle of.
    The gate is frozen but I'm going to take a shot at repairing as suggested. If I can't, I am going to replace just replace it.
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    Are you sure its even needed? Can you take some pictures of the connecting piping? Mad Dog
    kcoppethicalpaul
  • kcopp
    kcopp Posts: 4,735
    Simple fix is to get another swing check. Cut it out and mega press in another check….if the check is needed.
    The side view shows the hinge pin, I suspect. That is typically what the gate pivots on.
    Looks like maybe a test port up on the top.
    Do you suspect the gate is frozen in the shut or open position? In either case it should have an effect on the operation. I think you would need to take the top assembly cap off to know for sure.
    If it is frozen open and the system works properly, maybe it is not needed?
    You may find old stock Fairbanks checks on ebay.
    TheClevelandSteamer
    those were generally used on vapor systems in conjunction with boiler return traps. are you sure the check is bad and it isn't doing exactly what it was designed to do but some knucklheading of the vapor system is preventing it from operating as intended?
    109A_5 Posts: 4,759
    I'd also try to clean it first.
    If you need to replace it.
    Supplyhouse.com
    https://www.mcmaster.com
    I'm sure there are other sources for one.
    EdTheHeaterMan Posts: 12,940
    When you do the maintenance on that valve, are you going to sandblast or wire-brush the old paint off of it so it looks pristine? Or are you one of those “I don’t care what it looks like as long as it works” kind of guys?
    Asking for a friend. I don't want to say his name but his initials are @GW
    mattmia2GWold_diy_guySteve Minnich
  • GW
    GW Posts: 5,259
    Ed I’m too slow- can’t pick up what you’re putting down.
    hopefully the pipe renovations works well
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • rick in Alaska
    rick in Alaska Posts: 1,533
    If you do take the top off, the seal will be broken and you will have to reseal it to keep it from leaking. I have had good luck by taking some teflon tape and spinning it to make a "thread" of it, and then using it to wrap the threads with before putting it back together.
    Rick
    Larry WeingartenTMS1980
    pecmsg Posts: 7,634
    just cut a gasket that size.
    most often there’s a very thin fiber washer under the cap, or the cap was installed with Loctite.
    Since it is serviceable, I would guess it has a fiber washer.
    well, and unless it is some sort of commercial system where some utilization equipment needs a check valve, it is probably an 80 year old vapor system and long predates loctite
    i wonder if that pivot has to be greased to both seal and not bind up.
    A pic from a few steps back would help the steam pros determine why or if the check is even required..
    Has it been making any noise?
    Ideally a check valved is sized by Cv so that whatever flow goes through it can open the gate completely.
    If it needs to be in the system, and has to be replaced, Watts has a spring type,steam service specific valve also
  • Larry Weingarten
    Hi, I'll add that check was made when we expected to be able to service things. Notice how big the flats on the top are… nicely designed for a wrench or socket. I'd be tempted to hold the body of the valve with a pipe wrench and use a socket on the top/cap to encourage it to behave. 😊
    Yours, Larry
  • Thank you to everyone. The original one couldn't be salvaged. I replaced with a Legend unit that was a little shorter, so I just used a longer nipple.
    hot_rodPC7060
