Draining residential boiler in spring
Kev82
Kev82 Posts: 6
edited May 15 in Strictly Steam
After the winter and not using heat for 3 weeks, should I completely drain the boiler and piping?
    EdTheHeaterMan Posts: 12,691
    edited May 15
    Does your boiler use steam for the radiators or does it use water and a circulator pump?
    No in either case but some extra stuff for the steam boiler might be a good idea. If you are not sure than post a photo of the boiler and we will know.
  • Kev82
    Kev82 Posts: 6
    Yes it is a steam radiotor system. I treat the water in the boiler during the heating season.
    Jamie Hall Posts: 27,738
    IF you think you have a lot of sludge in the bottom, there'd be no harm to blowing that down — but then refill it and run it to full song to get the oxygen out of the water. Otherwise leave it alone.
    ethicalpaul Posts: 8,993
    If you treat the water, there shouldn't be hardly any mud in there. Drain off like a quart max and see how it looks. If it starts to flow pretty clear there's no sense draining any more IMO. I'm in full agreement with Jamie's "leave it alone" advice!
    Out of curiosity, what is your treatment methodology?
    dabrakeman
  • patrykrebisz
    patrykrebisz Posts: 143
    No. The insides of the boiler will remain moist for many weeks.
  • DanHolohan
    DanHolohan Posts: 16,732
    Please read this:
    https://heatinghelp.com/systems-help-center/what-to-do-with-boilers-during-the-summer/
    Retired and loving it.
  • Don_175
    Don_175 Posts: 178
    I just read that article. So, he was saying to remove the water in a steam boiler? Ours sits unused all summer. I always thought it should be left alone.
  • DanHolohan
    I would leave it alone.
  • Intplm.
    Intplm. Posts: 3,140
    @DanHolohan
    Did you ever take a creative writing class? Your writing style is entertaining while drawing the reader in. I guessed years ago that you were the author of Zoning Made Easy, and you verified that a few years ago on this forum. It's an excellent style that I have shared with many students in the past.
  • Fizz
    Fizz Posts: 580
    Just to revisit what to do with steam boilers in the off season. For years I never did anything with boilers as they supplied domestic hot water, but we just installed a new Peerless without domestic hot water. I've read where some recommendations are to fill with water to top of boiler(water lay-up), to empty it, to leave it alone and run it for about 10 minutes to keep internal parts lubed. What is best method?
    I doubt that you'll find much agreement on a "best" method. I prefer to leave it alone — most of the oxygen is boiled out of the water, and the interior of the piping and radiators will be at or close to 100% relative humidity. Some people like to fill the boiler higher, on the theory that that moves any corrosion which might happen at the water level to another area of the boiler. In that case, though, it is essential that the boiler be brought to full steam and the system filled with steam and then shut down — again to drive as much oxygen off as possible.
    I personally don't see much point in draining the boiler it introduces air to do that, and the boiler will be wet anyway.
    Intplm.
