Heat Pump Refrigerant Uncertainty
Hi all, I'm considering converting from oil to heat pumps but I'm wondering if this is not the time and I should hold off.
My concern is based on the fact that I see R-454B is being banned in Europe due to presence of PFAS, and closer to home, it seems that Maine is also restricting R-454B.
This would leave me to look into systems using R-32 but it would be nice to know where the industry is going to wind up.
Will there be a decision to invest in R-454B due to the further decrease in GWP that it offers compared to R-32, or is that overshadowed by the PFAS and will the industry settle on R-32?
I realize that I'm asking for the crystal balls to be broken out, but it would probably help the industry if it could settle on something for the next 10-15 years or so.
Thanks for any thoughts you might have.
    Jamie Hall Member Posts: 27,460
    Trying to predict the future on things like this is, frankly, a mug's game. If you really want to go heat pump — and they can be very good in the right application — go with the best you can find now. The rules will change, yes — but how, or to what, is impossible to predict.
    EdTheHeaterMan Member Posts: 12,386
    There must be something that is Flammable, Combustable, Toxic, Poisonous, Causes Cancer in California, is very corrosive, and is bad for the ozone layer, that we all can settle on. don't you think?
    mattmia2 Member Posts: 17,061
    don't worry, the fact that we as a species forgot how to make copper tubing around 2005 means that you'll be replacing it before you have to worry about a repair that requires recharging it.
  • Ironman
    Ironman Member Posts: 7,907
    Beware of the current hype that’s pushing for heat pumps everywhere. If you have an older home, a heat pump may not cut it.
    As far as what’s ahead: I’m hearing scuttlebutt about r290 (propane) being the next thing coming down the pike.
    Bob Boan
    Steamhead Member Posts: 18,582
    @charlie123 , what system do you have now?
    Consulting
    I wasn't going to say that… but the fact of the matter is that if you are pretty much anywhere north of New York City, you would be well advised to keep fuel based — in your case oil — heat for the colder days, as even a very good low temperature heat pump isn't going to keep you comfortable.
    The internet says it will! …and everything on the internet has to be true, right? Or the govenrment will protect us from anything that is not true, right?
    EBEBRATT-Ed Member Posts: 20,316
    R454B & R32 are not all that different. In fact I think 454B contains some R-32 or vise versa.
    I have herd nothing about 454B being banned. I have only herd it is or was in short supply.
    See the attached
    R-290 is already in use mostly in the food service industry and has been around for several years.
