Under the steam radiators.
Is that top part cast iron?
I was wondering the same under this hot water radiator.
I'd say they were to spread the radiator's weight around so the legs wouldn't wear out the floor.
Consulting4 -
and maybe the slotted middle provided a air gap to reduce heat damage to floor?
The first picture. The one on the top. The item on the right. That is the way they were installed. The other side has dimples on the end I think those dimples caught the floor for traction. These things seem to act like shock absorbers.
What are they??
@Alan (California Radiant) Forbes
The radiators look similar to the ones you refer to in that post but none of these are in that post.
@Intplm. If you look at that post, the third picture down has a pad under the radiator. I wasn't referring to the radiator, rather the pad which I had never seen before.
Two btu per sq ft for degree difference for a slab1 -
Yeah. That pad is cool. I never saw that before either.
I'm wondering if the same company made them.
So nobody knows what these are? They are under almost every radiator in the house.
They were/are under the legs of the rads. They flex and move up and down and back and forth slightly.
You can see from the pics they have dimples on the downside I would imagine to grip the floor. The tops are smooth to catch the feet. What the heck are these things?
Any chance there is a patent number on them somewhere? They look like someone's idea that never caught on.
I have never seen them before. I have a few guesses. 1) they are not radiator parts, but are designed to work with a machine,? or slip over a bolt or bracket to be removed easily, as a spacer during some manufacturing process?
My thoughts at first too. But under [all] of the radiators?
All radiators! sure. I spent a life of repurposing materials and parts from everything. I always considered it a bonus when I had lots of the same parts to use elsewhere. there was a guy who insulated his house with movie theater posters. He ran a movie theater. the posters were cut exactly the width of his 2*4 wall frame. when it was discovered years later, the posters being so rare, became a money windfall for the new owner. The art world is full of examples of materials turned into art. The only thing that made me think these brackets are not radiator leg supports is the open end and its uniform space as if it was a tool designed to wear that slipped over a bolt or rod. Like a spring tensioned bracket, the raised nodules on the one side lock it into place. Still, I do not know where they came from. I tried image search and radiator catalog search. It will probably be the previous owner, or a best friend machinist operator who would ever know. I saw a tool and die factory close that scrapped tons of stuff with large quantities of same parts. no longer even made or used.
Lost to history I say. It would be ironic to think it came from a foundry making radiators, but only from a machine used there.🙃 The internet is big, but reality is bigger and older.
It's been a while since this post. Was cleaning up the shop last night and found it again. Cleaned off the many layers of paint and other debris. It came out of a late Victorian three-story house. I replaced the steam boiler some time ago. These were under almost all of the radiators.
If I'm reading this correctly, it says "-Atlas- Radiator Pedestal," Norwich, Conn. PAT. MAR. 20H900…
I have never seen these before. Has anyone?
Think of all the floor that could have been save from divots
looks like those spikes are intended to put divots in the floor.
Smaller than the legs. There a way to many radiators that I have worked on that have sunk in the floor. I know the answer is money but why wouldn't the flare the leg out knowing how heavy radiators can get.
it is probably hard to cast and prone to getting broken
they were probably thinking that red oak strip flooring was the cheapest thing they could use for flooring.
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
