best penetrating oil for a rusted plug?
Doug_R
Doug_R Member Posts: 9
I have a Y-strainer that hasn't been cracked open for years. I've tried WD-40 Specialist Rust Remover over several days, but no luck so far. Here are two questions:
1) What brand of penetrating oil do find works best for hydronic systems?
2) To open the strainer, I could use two pipe wrenches; the second one pulls in the opposite direction to stabilize and reduce torque on the pipes. I'd like to try an impact wrench on low setting. In other situations (e.g.: rusted lugnut), high-frequency, low-duration impacts work better than a strong-arm . I would still use the second wrench to stabilize the connected pipes.
  • Any thoughts?
  • Intplm.
    Intplm. Member Posts: 3,079
    Pb Blaster. I have had some very good luck with it.
    There have been a couple of times when a heated-up fitting and pressing/melting a crayon, yes, I said crayon, into the heated joint can work well too. Take the one from the coloring book box that never gets used. 😉
    pecmsg Member Posts: 7,267
    When new pull the strainer nut and never seize it.
    What size strainer. Maybe replace the whole thing!
    Intplm.
  • Doug_R
    Crayon—it makes sense, because the wax can wick up into the threads and is also a lubricant. Thanks!
    Intplm.
  • Intplm.
    Excellent. If you do try it, please post your results.
  • Intplm.
    That plug…3/4" or 1/2" ? should come out. Pb Blaster? Apply it often over time if you have the time, and try it after a couple of weeks.
    I'm thinking you don't even need to do that. A couple of 18" or larger pipe wrenches should unscrew the plug as is.
    Doug_RAlan (California Radiant) Forbes
    mattmia2 Member Posts: 17,409
    that will probably unscrew with the right wrenches. the plug to just flush it should be easy, the cap to remove the whole strainer will take more force.
    Intplm.
    could replace the plug with a boiler drain and hose thread cap to make flushing much easier.
    Intplm.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,669
  • kcopp
    kcopp Member Posts: 4,699
    Heat. Kroil.
    Larry Weingarten
    Alan (California Radiant) Forbes Member Posts: 4,800
    edited May 6
    I never understood why plumbers install strainers with a plug instead of a bibb drain. See it all the time.
    mattmia2Doug_RIntplm.
    hot_rod Member Posts: 27,806
    What type of piping in the system?
    Do you really need a Y strainer? Looks like it has never been drained or disassembled?
    EBEBRATT-Ed Member Posts: 20,461
    Kroil Oil is the best IMHO.
    Y strainers are difficult to get the wrenches on especially in a tight spot.
    I would unbolt the flange below the strainer and unscrew the strainer off the copper adapter.
    Then you can put it in a vise and get the plug out. I would also while it is out remove the bushing and take the screen out and clean it. Put everything back together with teflon tape and "Never Seize" as @pecmsg mentioned and a drain valve instead of a plug. You are in an awkward position with the strainer vertical and the wall to get leverage on it.
    Doug_R
  • Doug_R
    Ed, that is great advice (to "unbolt the flange below the strainer"). Get that strainer away from the pipes and walls and entanglements, and work on it in a vise. I wish I'd seen it\\your comment earlier.
    I was able to get an electric impact wrench with an oversize socket on it. The frequent, short bursts smoothly did the job. The strainer was packed with magnetite. It feels so good to put it back clean.
    Thanks to each of you for your advice and insights.
    Doug
    Intplm.
    if the system is empty, heating the casting seems to always loosen stubborn threaded connections
