EK1 5" chimney liner and condensation ?
arcticman
arcticman Member, Email Confirmation Posts: 42
edited May 8 in Oil Heating
We live in Alaska and I'm getting mixed opinions regarding using a chimney liner with the EK1 in a cold climate.
Will installing a 5" chimney liner into are existing ~30 foot 7" double walled SS vertical flue create a problem with condensation forming and collecting at the bottom of the 7" flue and then dripping on top of the boiler?
Thanks
  • Robertw
    Robertw Member Posts: 85
    Our ek-1 frontier uses a 5 inch flue connector to the chimney. Which boiler are you thinking of useing?
    Robert W.
    Energy Kinetics
    pecmsg Member Posts: 7,191
    might as well pull a new 4” flew
  • arcticman
    edited April 30
    Looking at the ek-1 system 2000…. sorry I meant 5" flue.
  • Robertw
    That will take a 5 in chimney liner and 5 in from the boiler to the liner. Use an increaser to step up from the 4 inch flue collar at the boiler to the 5 inch.
    Robert W.
    Energy Kinetics
  • HydronicMike
    HydronicMike Member Posts: 363
    You’re fine, if properly installed, emphasis on 'properly' as per the manual. Which should include cleaning the existing and a Level II inspection.
    Lyle {pheloa} Carter
