Connection from Taco SR501 to RINNAI I-Series combi boiler
I understand the I-series boiler has a switch relay internally for single zone. I have already set up a switch relay and grundfos pump powered separately from my boiler. I have a tekmar smart thermostat already connected to the switch relay. I need to know how to connect my switch relay to the combi boiler. I am thinking the T/T 1 Connection at the boiler to the C and N/O connection at relay but the t/t conn has the three connections C, R and W. Is there a different place in this panel I should connect for call for heat when pump kicks on?
    Jamie Hall Member Posts: 27,415
    Use R and W on the boiler. C is provided for a common return from powered thermostats.
  • MountainView
    MountainView Member Posts: 3
    ok. So c and w on boiler to the n/o and c on relay?
    EdTheHeaterMan Member Posts: 12,322
    edited 3:26PM
    R and W will run the boiler. R and W. = Will Run
    In this illustration I have fadded out the unimportant parts of your photo and highlighted the important parts of the diagram. Take 5 (COM) from the Taco SR501 and connect it on R for zone 1 of the Rinnai I-Series. Take 6 NO from the Taco SR501 and connect it to W on the Rannai I-Series as shown above.
    109A_5 Member Posts: 4,104
    edited 3:18PM
    The common and the N/O on the relay really don't matter which go to the R or W on the control board. The ''C" on the control board is not used.
    It just acts like a switch, closed calls for heat, open no call for heat.
  • MountainView
    Thanks everyone for the direction.
