Connection from Taco SR501 to RINNAI I-Series combi boiler
I understand the I-series boiler has a switch relay internally for single zone. I have already set up a switch relay and grundfos pump powered separately from my boiler. I have a tekmar smart thermostat already connected to the switch relay. I need to know how to connect my switch relay to the combi boiler. I am thinking the T/T 1 Connection at the boiler to the C and N/O connection at relay but the t/t conn has the three connections C, R and W. Is there a different place in this panel I should connect for call for heat when pump kicks on?
Use R and W on the boiler. C is provided for a common return from powered thermostats.
ok. So c and w on boiler to the n/o and c on relay?
R and W will run the boiler. R and W. = Will Run
In this illustration I have fadded out the unimportant parts of your photo and highlighted the important parts of the diagram. Take 5 (COM) from the Taco SR501 and connect it on R for zone 1 of the Rinnai I-Series. Take 6 NO from the Taco SR501 and connect it to W on the Rannai I-Series as shown above.
It just acts like a switch, closed calls for heat, open no call for heat.
One Pipe System0 -
Thanks everyone for the direction.
You know you could have just wired everything up directly to the boiler?
I think there is a rule about how many valve handles you are allowed in a 5 square foot area. You have certainly gone over the allotted amount here. You may get a call form the valve division of the mattress police if they ever get a look at this photo.
It is a nice looking job!
- 135 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
