AC mini booster
EdTheHeaterMan Posts: 12,857
is anyone here familiar with the concept of the AC booster?
is this something new? I don’t recall seeing it before I retired.
mattmia2Intplm.GGross
    pecmsg Posts: 7,613
    edited April 21
    Face Plant
    Now………Did they get paid to do that?
    EdTheHeaterManIntplm.
    EBEBRATT-Ed Posts: 21,169
    Looks like a gas fired make up air unit that had no cooling ………but it does now!!!!!
    I want to know how to wire it in? Or does it use the same little man that lives in the refrigerator that turns on the light bulb when you open the door?.
  • ratio
    ratio Posts: 4,329
    edited April 23
    Retrofit AC on a 100% outside air MAU. It's the maintenance man special, things like that are how he saves the company 10's of thousands of dollars every year.
    I gotta admit, it's cheaper than having us replace it with a heat/cool unit…
    Now we are getting into some really interesting territory. Do you set the window unit to high cool and just plug it into an outlet that is operated by a sail switch and contactor, or do you put that stuff inside the window shaker?
    Perhaps Paul can do a video and I can make up some outlandish convoluted wiring diagram.
    Intplm.
  • Seriously guys. Why the attitude? Obviously, the company long known for redneck mobile climate control solutions has expanded into commercial equipment. Don't be jealous!
    Seriously, as far as Ed's post, I'd bet a beer that the thing is powered by an extension cord inside the make-up unit connected to one leg of the three phase on the load side of the contactor. Since there's probably no neutral up there, I'd guess they are using the equipment ground for a neutral. I'd also guess that the filter has been removed - although I suppose it doesn't really matter in this particular application.
    Larry WeingartenEdTheHeaterManbburdGGross
    @Illinoisfarmer has an uncanny eye for the obvious detail when it comes to redneck engineering. I have said it before and I will say it again:"
    You are truly a man outstanding in his field
    Illinoisfarmer
    mattmia2 Posts: 18,233
    why not put a generator on the pto?
  • Tom in Maine
    Tom in Maine Posts: 26
    That is a silly question: We all know heat rises!
    Tom Gocze
  • This is high class redneck engineering. Notice the framing around the AC unit. Notice the two disconnects on top. I think there is another AC on the other side.
    hot_rod Posts: 28,528
    looks like he ran out or green and yellow JD paint
    If heat rises… why is it so cold in Maine in the winter….
    Maine is higher on the map than Florida! Dah!
    Didn't you pay attention in 5th-grade Meteorologeography class?
    Or do they teach that new upside-down math in Maine?
    SiteReader
  • Larry Weingarten
    Larry Weingarten Posts: 4,204
    Hi @EdTheHeaterMan , Sometimes knowing which way is up can seem like an art form. 🙃
    Yours, Larry
