Ran out of oil, unable to restart with bleeding
Juggatweet
Juggatweet Posts: 17
edited February 25 in Oil Heating
EK System 2000 - usually when we run out I grab 5 gallons of diesel, dump it, bleed it and it's good to go. I've done 10 gallons of diesel and bled it at least 10x still goes off as soon as it gets to ignition eact time. Do I just keep trying?
  • "…usually when we run out…" Stop running out. You're not helping your system
    Either you're not doing it correctly, you clogged up your oil line/filter/strainer/nozzle, or you did bleed it correctly and it's not lighting.
    Time to get someone in there who knows what they are doing.
    RobertwJuggatweet
    pecmsg Posts: 7,613
    Do you let your vehicle run out of fuel?
    Juggatweet
  • Thanks @HydronicMike I realized I was leaving the bleeder open too long, closed it timely and it started up the first time. Not running out of fuel would be a great plan, I just always forget to check it. #goals
    Big Ed_4Robertw
  • Don_175
    Don_175 Posts: 179
    check out the Smart Oil Gauge. Easy to install and sends alerts to your phone. We have one. It’s great. Www.smartoilgauge.com
  • Jon_blaney
    Jon_blaney Posts: 350
    Get an auto fill plan.
