Skimming Sump Setup
markmarlatt
markmarlatt Member Posts: 106
I am getting prepared to skim my boiler once the tech installs the skim port which was never tapped on my boiler. My basement has no floor drain currently (another long term goal) so I was curious about setting up a bucket with a sump pump to evacuate the water from the skimming process up and out my basement stairs. Curious if such a setup already exists?
I have a manually operated sump pump already, however given the skimming process can take a good deal of item, I wanted to build an assembly which would kick the sump pump on once water reaches a level in the bucket.
I plan to put the bucket into a pan which then has water sensors from my Ring security system. This way, if I have to step away from the boiler while skimming and water gets out of the bucket (say pump failed), I get alerted to matter. I am a IT Engineer and have a love for gadgets, but I'm short on knowledge regarding sumps. Any ideas?
    mattmia2 Member Posts: 17,902
    it should just be a thin stream of water, probably easier to just have a couple buckets and dump them.
    you can get a sump pump with a vertical rod type float switch already installed on it that you could put in a bucket. there are tilt type float switches that piggyback on the plug for the pump but those might be hard to get to work right in a narrow bucket.
  • markmarlatt
    Awesome, I found a sump with a built in float that engages pump at 4" of water and off at 2" of water, so that should work nicely. I'm guessing the skim will take several hours and/or days given its never been done given the skim port is still plugged/capped. Fun stuff….
    you probably will have to do it multiple times. As the system runs the steam and condensate bring more oil back to the boiler so it isn't a one time thing but once you get most of it out you don't need to do it again, it is just a new install/new piping thing.
    Probably an hour or so at a time is what makes sense, if you keep doing it for hours you aren't really getting more oil off and more oil is going to work its way back to the boiler. it will help if you fire the boiler to keep the water just below boiling as you add more water and cool the boiler.
    Never had to skim one longer than an hour myself. I would check to make sure the sump pump can deal with 190-200 deg water.
    ethicalpaulpecmsg
  • markmarlatt
    edited April 3
    good point, the sump temp limit is 140 degrees. Seems I’m destined to babysit the bucket. Will target each skim for 60 minutes then run system a day then skim again. My goal is to stop or reduce the surge and get the water in the glass less oily.
    edited April 3
    you could just run it in to a condensate pump too
    you can probably fudge the temp a bit if you're just using it like 5 times to skim a boiler vs every day for 30 years
  • ChrisJ
    ChrisJ Member Posts: 17,622
    I just took several 5 gallon buckets, did my skimming and then let them sit and cool down.
    I did that many times. You can then either dump them into a sump pump or use a pump in them. Or do like I had done and carefully carried them all up out of the basement.
    ethicalpaul Member Posts: 8,978
    edited April 3
    Just use a couple buckets. Just skim a half hour or so at a time (I do it until the water starts to run warm—I didn't say "cold", that would take hours). Anything more than that is wasting your time. Then as @mattmia2 said do it again if needed after a couple days which gives the oil a chance to break loose or return to the boiler/wash down from any new piping.
    I know others said this, but you seemed to really be set on setting up some kind of sump pump so I'm repeating to try to get you away from that idea.
  • markmarlatt
    edited April 3
    yeah I’ve given up on sump pump and will do good ole 5 gallon buckets. Plan to limit skims to max of 45 min, run system a day then repeat. Guessing it will take at least 5 skimming to get years worth of oil build up out.
  • markmarlatt
    Is the ideal skim to have a nipple then full port ball valve then nipple then a tee to see water level in pipe then nipple and elbow as needed?
    My goal is to have a skim line made such that it passes the vertical drops in pic above then an elbow and another nipple to drop nicely into a 5 gallon bucket on the floor.
    Like this:
  • neilc
    neilc Member Posts: 3,201
    I would do a short nipple thru the jacket, and ball valve, then have the extension nipple and drop El removeable(loose ish), so you don't have much leverage hanging out there, a plug in the valve when not in use,
    known to beat dead horses
    markmarlatt
  • markmarlatt
    edited April 4
    Ahh yes, will make the post valve nipple, ell and down nipple removable.
  • geemalar
    geemalar Member Posts: 100
    Not that it really matters, as you have to work with what you have, but is there a benefit to the skim port location whereas:
    In the boiler above, with the skim port just in the general area of the normal water level, you don't have to raise the water level in the boiler so much to skim it.
    Or as in my boiler, where the skim port is almost at the top of the boiler (just about where the screw is to the right of the white label) where you have to fill the boiler almost to the top to get it to run out the skim port.
    Would the higher level help capture and help bleed off any contaminants on the last 1/3rd of the boilers upper chamber, or there's really little difference in either skim port location.
    Apologies on asking, but I'll soon have legitimate meaningful questions on sizing up the main venting on my system along with replacing/fitting a steam radiator in my bathroom and removing the small slant fin arrangement from when we bought our house.
    the skim port has to be above where the tops of the boiler sections connect together oteherwise you will only skim off the oil in the section that has the port in it.
  • markmarlatt
    In my case, the 3/4" port on the right is at 23 7/8" and the water line is at 23 1/4", so the skim port is 5/8" above the top of the boiler sections. Not thrilled that the port is only 3/4" in size, but can't change that without changing boilers…
    I would forget the "down elbow", there's no need to aim the water down toward the bucket, since gravity will do that for you. If you leave it horizontal at the end, it's easier to see any oil sheen coming out.
    You can look at mine in many of my videos linked below if you want. I have a tee on mine with the middle part facing upward so I can see down into the flowing water to even easier see any oil sheen before it drops out the end.
    reggi
  • markmarlatt
    I purchased a full port ball valve and tee based on your videos :)
    I'm going to use a funnel and hose hung off the end of the horizontal to direct flow to the bucket given that the process should be few and far between.
    Oh cool, I hope you make a video to show us how it goes!
    markmarlatt
