Boiler sizing based on EDR
Ldallas_87
Ldallas_87 Member Posts: 22
I need a new steam boiler. I calculated my current EDR as 370 without the piping pick up factor. When looking for a boiler do I just need to match the boiler steam sq. ft. output to the EDR because the boiler steam rating includes the 33% pick up factor that I did not account for? For clarity, based on the ratings for Burnham Independence boilers: the IN5I would be slightly below requirements and the IN6I would be somewhat oversized?
    Jamie Hall Member Posts: 27,367
    Match the boiler Square Feet rating to the EDR — don't add anything else. If the match isn't perfect (it rarely is!) better to go slightly undersized than go oversized — so in this case the IN5I would be the prper choice.
    ethicalpaulRobert_H
    ethicalpaul Member Posts: 8,788
    Although a Burnham IN model is possibly the worst choice amongst all the available boilers
    STEAM DOCTORRobert_HSteamhead
  • Ldallas_87
    Thank you. What would you recommend ethical Paul?
    EBEBRATT-Ed Member Posts: 20,172
    I hate Burnham but the "Steam Max" is their best boiler. Otherwise, Peerless or Weil McLain. Weil McLain also makes the Williamson brand. A few $$$ less same boiler.
    Burnham Independence has a poor track record. You don't want that one. There are a few other decent boilers but most are "rebranded".
    Burnham in particular sells a lot of boilers with different names on them but they are all Burnham. Crown, New Yorker et are Burnham clones afaik
    Robert_HethicalpaulSteamhead
    Peerless. I like Utica fine. I’d like Weil-McLain but they say the pH shouldn’t be above 8.5 and that’s strange to me.
    It makes me think they have problems with their elastomer seals that they blame on pH level. But that is conjecture and I have friends with WM who are happy with them.
    Yeah. I forgot Utica/Dunkirk are fine as well.
  • ChrisJ
    ChrisJ Member Posts: 17,378
    Sounds like a good system for a WM EG40.
