How to store a cast iron boiler
luna12
luna12 Member Posts: 6
I have a Weil-McLain CGa-6 cast iron boiler. It is not connected to my system yet and I just did a pressure test on it. It passed. I likely won't install it until maybe June or July, so I'm wondering what would be the best way to store it until then. I've read about both wet and dry storage. Should I keep it filled with the water I just used during the pressure test and maintain a small amout of pressure in it? Or should I drain it and dry it out? Or something else?
    pecmsg Member Posts: 7,050
    if the H2O has no ox flood it
    If not I’d pressurize with N2
    luna12
    mattmia2 Member Posts: 16,718
    note that at the factory they pressure test them, drain out what they can, then crate it up and let it sit on the shelf for months until someone buys it.
    ethicalpaulEdTheHeaterManluna12GGross
    ethicalpaul Member Posts: 8,770
    EdTheHeaterManmattmia2GGross
    EdTheHeaterMan Member Posts: 12,145
    Perhaps you can use dry nitrogen, using a triple evacuation method to remove all the moisture, then hermetically seal it with a nitrogen charge. Then you will be sure that nothing will go wrong @pecmsg and Paul can do a Video on it.
    ethicalpaulmattmia2old_diy_guy
    EBEBRATT-Ed Member Posts: 20,162
    I would get a high velocity fan and blow air through it. A handheld leaf blower will work. The friction of the air will raise the air temp which will absorb the moisture in the boiler.
    We used to use this with chillers that broke/froze a tube and got water in the refrigerant to dry out the water.
    luna12
  • luna12
    The point about how they handle things at the factory is a good one. I also like the idea about speeding up evaporation with a leaf blower. I think I'll go that route.
  • Intplm.
    Intplm. Member Posts: 3,010
    Do nothing.
    @luna12 What you may have read would be a way to "lay-up" your boiler [ IF ] it was in service. In my experience that would be called a "wet lay-up" meaning the boiler is filled with water till it's ready to be put back into service. Your boiler is new and not installed. Do nothing to your uninstalled boiler.
    hot_rodmattmia2ethicalpaul
  • luna12
    edited 5:35PM
    @Intplm Just for clarification. By "do nothing", do you mean just leave it full of water until I install it? Because, like I mentioned, it's currently full of water from the pressure test. Or do you mean empty it, and "do nothing" once I empty it?
    Just to displace the O2.
  • Grallert
    Grallert Member Posts: 1,116
    Empty it and leave it alone. You will do it no harm
    luna12
