How to store a cast iron boiler
I have a Weil-McLain CGa-6 cast iron boiler. It is not connected to my system yet and I just did a pressure test on it. It passed. I likely won't install it until maybe June or July, so I'm wondering what would be the best way to store it until then. I've read about both wet and dry storage. Should I keep it filled with the water I just used during the pressure test and maintain a small amout of pressure in it? Or should I drain it and dry it out? Or something else?
and people call me extreme!! š
See my sight glass boiler videos: https://bit.ly/3sZW1el3 -
Perhaps you can use dry nitrogen, using a triple evacuation method to remove all the moisture, then hermetically seal it with a nitrogen charge. Then you will be sure that nothing will go wrong @pecmsg and Paul can do a Video on it.
4 -
The point about how they handle things at the factory is a good one. I also like the idea about speeding up evaporation with a leaf blower. I think I'll go that route.
Do nothing.
@luna12 What you may have read would be a way to "lay-up" your boiler [ IF ] it was in service. In my experience that would be called a "wet lay-up" meaning the boiler is filled with water till it's ready to be put back into service. Your boiler is new and not installed. Do nothing to your uninstalled boiler.
3 -
@Intplm Just for clarification. By "do nothing", do you mean just leave it full of water until I install it? Because, like I mentioned, it's currently full of water from the pressure test. Or do you mean empty it, and "do nothing" once I empty it?
Just to displace the O2.
