Old Forgotten Ways
@Mad Dog_2 I used to tell my CO to just tell me what he wanted done and let me figure out how to do it. He learned it was best if he did not know how it got done.
'These days you hear about the E4 mafia in the service, back in the 60's it was the SP5 mob. E5 was just high enough to get you out of the swamp (guard duty and KP) but not high enough to burden you with any real responsibility - that freed us up to work the deals that kept the organization going. It worked very well till some Lt asked "how did you do this", mu answer was you don't want to know.
3PSI gauge1 -
I have seen electricians trace wires in interesting ways. One guy had a light switch in a regular switch box with a male plug. One wire went to the hot blade and the other to the ground prong. He would flip the switch to off, plug the pig tail into an outlet, then flip the light switch on. Then go to the service panel to see which breaker tripped.
A safer method, which I have seen many times, but never took the time to figure it out, two old fashion telephone handsets and a 9v battery. If you were on the same wire, you can speak to each other.
Don't know why the switch and plug all you have to do is short the hot to neutral or ground. I never have done that (at least not intentionally). Just don't think it's a good Idea.
Especially if you have a Federal Pacific Panel.
I have an Ideal breaker finder. Must be 15 years old. Plug the transmitter in the outlet and go to the panel and check for what circuit rings.
It's not 100% but in most cases, you can find the right breaker within a min or so. They probably have better ones available now.
2 -
a d cell would probably be sufficient, you just put the transmitter in series with the battery and the carbon mic element makes a varying current from speech that the speaker in the receiver can turn in to sound.
there were some that used a dynamic mic that could produce enough current to power the receiver just from the sound.
Ah yes. The game of which breaker does what. Cedric's home is almost all fuses, except for two panels and a couple of sub panels. We found (the hard way) that the fancy circuit tracers simply don't work well with fuses and BX cable — But with the aid of patience and cell phones we traced every light and every socket to the relevant fuse. And it's all listed on laminated sheets next to each panel (not just "east bedroom" either — "socket at south end of east wall in east bedroom".)
And before anyone has hysterics, all the wiring conforms to the code current as to the date it was installed (most of it 1955 — long story), and every single fuse has been checked to be correct for the wire gauge and insulation type, and they are all guarded. Among other things, with the guards you can't put in a larger fuse than required, nor can you short the fuse with a penny…
There is some good humour, though, in the main entrance — because of code issues and a 15 KW solar array and a whole house transfer switch, there is a dizzying array of 4 200 amp two pole circuit breakers on the way in… to 200 amp fast blow cartridge fuses… all in series.
most branch circuit wiring is capable of safely carrying more current than what the code requires it be fused at anyhow. the ampacity is by decree in a rule, not by heat generated and insulation temp rating
electrical fires happen far more from bad terminations than from overloading the conductors.
The fuses that fit those guards were called "Fustats". My house used to have them.
2 -
are we just talking type s fuses and those adapters that make it a huge pain if you need to fix something with the fuse panel?
The new afci breakers make the process of finding the breaker simple; touch neutral to ground to pop the breaker.
True. But they also prevent putting the wrong rating fuse in…
I'd love to change everything over to modern breakers. Maybe when I win the lottery… but then again, the fuses work. Every time.
the early site made fuse panels with individual fuseholders were usually pretty sketchy but most of the mid century factory made fuse panels are pretty solid as long as they didn't get wet. i have seen a lot of sketchy 70's era fuse and breaker panels, even ones that aren't the infamous ones. should there be more than just a piece of glorified cardboard keeping the bus from touching the enclosure?…
" but then again, the fuses work. Every time. " Yes they do.
It is interesting how human laziness and incompetence breads inferior technology that most folks like.
One Pipe System0 -
Ah so? A modern fuse is hardly inferior technology. I'll grant that there are two add-ons which fuses can't do — ground fault protection for milliamp faults and arc fault protection (but that latter, in my humble opinion is not a mature technology at this point). The type S fuses — the only ones I'd use in fuse panels with Edison type bases — are "slow blow" fuses, meaning they have a time to blow vs. current curve which allows for momentary overloads, such as motor starting or even current inrush on some lighting applications. However, in cartridge fuses the range of time delay on overcurrent is extraordinarily large, ranging from fuses — like the type S, but with more variety in time delay — to fuses which will blow reliably with microseconds of a current ramp exceeding their rating, which — obviously — should only be used to protect very sensitive electronics.
One of the overlooked aspects of fuses — particularly cartridge, but also type S — is that it is almost impossible for them to fail fused closed, unlike almost all enclosed circuit breakers which can and do fail closed if presented with a high overvoltage at the same time as a high current.
It is no coincidence that virtually all grid wiring and devices are protected by fuses. Circuit breakers are used in places like substations, but more as high voltage switches with reclose capability, and there is almost always a fuse in play as well.
Now I quite agree about looking at older fuse panels with some suspicion! But that also applies to some older circuit breaker panels. Now if you encounter a fuse panel which has NOT been converted from Edison base to type S, either replace it with breakers — or just add type S converters (check the wire gauge and insulation type for proper size!)
And if you encounter a panel — of any type or age — which has gotten wet, just replace it. It's done.
And don't assume that someone along the line has always used the correct rating circuit breaker. It is just as easy to swap in a higher rating circuit breaker for a circuit which is overloaded as it is to swap in a higher rated Edison base fuse. There is ample YouTube guidance for the ambitious homeowner to do just that…
@Jamie Hall said "And don't assume that someone along the line has always used the correct rating circuit breaker. It is just as easy to swap in a higher rating circuit breaker for a circuit which is overloaded as it is to swap in a higher rated Edison base fuse. There is ample YouTube guidance for the ambitious homeowner to do just that…."
Proving, once again, that you can't fix stupid.
But duct tape can make it less noisy.
4 -
it is significantly more difficult unless they are type s fuses but it is still doable.
the problem with figuring overcurrent protection after the fact is that you have to examine the whole circuit both for gauge of wiring and for utilization equipment that may need a lower rating of overcurrent protection than the wiring or that may fall under one of the next standard size up exceptions.
i'm not sure about the AFCIs. The ones I installed 20 years ago needed to bake some more but the ones I bought about a year ago seem to have solved most of the problems of the early ones.
@Jamie Hall "Ah so? A modern fuse is hardly inferior technology."
I think you read it wrong or I wrote it wrong. I like fuses !!!
I don't like circuit breakers (the more modern tech). A fuse, a proper fuse always blows, circuit breakers, well who knows.
Since humans blow fuses and were not competent enough to remedy the reason why the fuse blew so they would put the wrong fuse in to replace the blown one, they also had to buy a new one for every one they blew the circuit breaker (inferior technology, but resetable) was born.
One Pipe System0 -
how does a remote trip fuse work? say you want the main to trip if you detect a fault in a surge suppressor, how do you do that with a fuse?
As I recollected on this, I think he had a circuit breaker with a pigtail, not a light switch. Less spark and no bark compared to shorting. Just a click. We use fox and hound tracers and are usually good but sometimes, the tone can be heard over multiple breakers.
@SlamDunk I had a Fox & Hound and had no luck with it so I tossed it. My old Ideal is pretty good. It does some cross talk and isn't 100% but most times its ok.
As far as fuses and breakers I would take fuses any day.
But they don't make AFCI or GFCI fuses yet😎
Heat and/or a crowbar circuit.
One Pipe System0 -
Except those mini-breakers — which work — are standard Edison base, rather than type S, and are subject to the same critical flaw: you can substitute a larger size for what should be there, and people do. I, at least, would not accept them in a panel I was responsible for.
there is no way to key cartridge fuses, right? some have a key for interrupt rating but they do not have any keying for ampacity
Cartridge fuses no you can replace a 15 with a 30 or a 35 with a 60 or a 70 with a 100 etc.
I guess they were mostly concerned with home owners.
I had a neighbor a few houses away years ago. Holly managed a rock & roll band. I won't say any more. Her furnace quit in mid-winter and she already had someone signed up to do that.
So, with the furnace being out she went out and bought a bunch of space heaters and plugged them in. She called me to see if I had fuses.
I went over and almost every fuse was too big. A couple were "S" fuses where she tried to put in the wrong ones. I had a whole box of fuses I used to save from changing services to breakers. She had plugged multiple heaters into the same circuit.
The whole band was there, and the alcohol was keeping them warm among other things. So I straightened things out and moved the heaters to different circuits and made sure the fuses were the right size for the conductors.
6 months later its summer and she calls me at midnight for more fuses. She decided to have the band strip the wallpaper (yeah at midnight) and they were sloshing water and vinegar on as wallpaper stripper. Some of it got into a light switch and the sparks flew.
I went down to the panel and everything was all messed up again.
Yes you can put the wrong cartridge fuse in in many cases, at least within limits. As @EBEBRATT-Ed said, I think the concern is more about homeowners. There is a more subtle problem with cartridge fuses, though. They come in various current/time configurations, and one needs to be sure that one is replacing both the ampacty — and the type. To a certain extent, though, they aren't completely interchangeable, as some have a different clip configuration (the fast blow ones for solar panels, for instance).
I love that horror story… are you sure it was just alcohol that kept that jolly crew flying, @EBEBRATT-Ed ? Or didn't you ask…
Both times I was there I wanted out as quick as possible. 😎
Yeah, they're more worried about homeowners.....
2 -
Hi, You keep posting pictures like that and you're going to turn @EBEBRATT-Ed 's stomach! 🤮
Yours, Larry
2 -
Yeah.....
It's bad.
I've seen that… and not just homeowners….
Yeah…it is.
I'm defrosting 3 of our fridges today. It takes almost no effort but apparently it's too difficult for most.
the keeping the food cold while it is happening is the hard part. my basement freezer only gets defrosted when it is around 0 out
Chest freezers are a little harder but even more worth having manual defrost on.
My normal fridges I turn off, put a 1 gallon Ziploc of hot hot water in and let it defrost. Once the ice releases I pull the chunks out, pour the tray out and drain it and restart. Nothing gets above 40f
This is my son's 1935 ball top being defrosted.
the basement freezer is an upright about the size of 2 dorm fridges. it is branded coldspot so i assumed it was made by whirlpool but i saw it in a sears catalog marked as made in germany so it might be something else. defrosting it involves the garage being around 0 and a couple cardboard boxes. i have a picture of the rating's plate that is conveniently located on the back with the source code number somewhere.
i'd imaging those pre 50's impractically small freezers defrost pretty fast.
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
