bending fuel oil line
Robert_H
Robert_H Member Posts: 288
How do you bend coated fuel line? so far I gotten away with bending around a piece of pipe or a can etc. So I figured I would up my game and picked up a Kline roll bender "Klein-Tools-51006-3-in-1-Tubing-Bender"
The plastic gets beat up a bit and it just one radius.
    mattmia2 Member Posts: 16,302
    the groove needs to match the od of the tubing and coating. there are also internal and external bending springs. how many radii do you need? you just bend it until you get the angle of the new direction that you need.
    Robert_H
  • HomerJSmith
    HomerJSmith Member Posts: 2,769
    edited February 17
    That's the kind of bender I use on small tubing. If you are having scuffing, try spraying the tubing with silicone spray before bending. Make sure the silicone spray is suitable for rubber and plastics, not all are.
    Robert_H
  • HydronicMike
    HydronicMike Member Posts: 315
    Unless you need a tight 90, bend it by hand, working it up and down the bend a little. Otherwise use the size bender for the outside diameter of the tubing with the jacket.
    Robert_H
  • Robert_H
    thanks, but where do I find a tubing bender that is 3/8 plush that jacket?
  • Robert_H
    "the groove needs to match the od of the tubing and coating." yes, but who makes this?
    pecmsg Member Posts: 6,993
    refrigeration 1/2”.
    plenty of electrical lube
    Try not to slide the tool but walk it.
    mattmia2Robert_H
    a little bit bigger is probably ok. a little small is going to tear up the plastic which its probably just a cosmetic issue.
    edited February 17
    you can also fill the part you want to bend with water and freeze it. it won't burst if it is a short section. both have issues with getting the line clean enough for fuel afterword.
    and you won't need a second mortgage for the r22 like Ed's method.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,476
    edited February 17
    I can't see using a bender on contained oil line ? A boot works in the corners ..
    For bright work I like ratchet type , looks like a cross bow . You would need try the larger size
    HVACNUT Member Posts: 7,367
    I use the 1/2" block to bend 3/8" coated oil line. I have this mostly for refrigerant piping.
    While I was looking for a pic of that one, a came across this.
    This was on the HD website.
    pecmsg
    EdTheHeaterMan Member Posts: 11,931
    I have that set @HVACNUT but the bending forms are all black plastic like the clamp die. I like your pretty colors!
    Robert_H
  • Robert_H
    @HVACNUT thanks, we have a bender like that for refrigerant in the "big/installation" van. Its awkward in tight spaces but good to know coated 3/8 oil line fits a refrigerant line Die>
    hot_rod Member Posts: 27,212
    I know REMS , and maybe the other German benders have metric sized heads available. Measure the OD and see how it converts to metric sized
    Robert_H
    EBEBRATT-Ed Member Posts: 20,025
    Its only 3/8" I would just bend it by hand.
    do you need cotton gloves to use it?
    @mattmia2
    Can't get hands dirty.
    i watched a video of someone using foam in a can without gloves the other day. there are lots of things that i don't wear gloves for and lot of other things i sometimes wear gloves for because it is easier than scrubbing my hands in gojo or paint thinner but latex or nitryl gloves are great for foam in a can because more or less nothing takes that stuff off.
